I'm running an Asus RT-AC86U, with Asuswrt-Merlin.
Before upgrading to 384.16 everything was okay; but since the upgrade the router is no longer able to connect to the Internet. The Web UI works okay, WiFi is up and accepting connections, but it claims the ISP is not responding correctly to DHCP requests. That could be true, I suppose... but that it should start claiming this immediately after an upgrade is suspicious timing.
It's connected to a Virgin Media "Superhub 3" in modem mode. (I'm in the UK). The Virgin hub reports that it's connected to the Internet okay (and switching it temporarily into router mode worked okay too) so there's no obvious problem there.
I've tried rebooting everything several times - didn't help. I've also tried reflashing 384.15, but that hasn't helped either. What's the next step?
