OzTrip
Hi there,
I'm having an issue with my RT-AC86U
The area affected: LAN > Static Route List
Tested on stock: RT-AC86U_3.0.0.4_384_81369-gb361479_cferom_ubi.w
Tested on marlin: RT-AC86U_384.16_0.zip, RT-AC86U_384.15_0.zip
Tested on Chrome, Safari, Edge & iPad
Manual entry, re-flashed, reset multiple times. Everything else works fine...
Replications steps:
1. Insert any static route eg.
2. Click Apply
3. Log In (you can see the changes saved correctly)
4. Reboot
5. Navigate to LAN > Static Route List
Result: All static routes are wiped off.
I tried multiple times, I can save other settings.
Q1. Does anyone have any idea what can be wrong?
Q2. Can I update Static Route via SSH? If so how? Thanks
Replications steps:
2. Click Apply
4. Reboot
