dylanmitchell
Picked up an RT-AC86U to replace a WRT 1900AC and have it set running but two settings are frustrating me. I'm running the stock firmware on the RT-AC86U and want to disable wireless access to router settings so the router settings can only be accessed via hardwired ethernet (disable remote administration). Also, how do I set the modem to auto update firmware? I want it to automatically install firmware so I don't have to connect it to a computer to check and updated firmware. Running stock firmware no Merlin no DD WRT. Asus tech support hasn't been of any help they suggested setting that would disable wifi entirely not just access to router settings.
On the Linksys WRT 1900 AC both settings were in the router menu I was easily able to have wireless access to settings disabled and set the router to auto update firmware which is great for a device you rarely log into and check for updated firmware. I really like the WRT 1900 AC but after a couple of years, wifi was getting spotty and immediately improved with the AC86U. Not sure if capacitors or other electronics in the router wore out.
Thanks.
Thanks.
