RT-AC86U - works perfectly except for all my PLAYSTATIONS!
preseznik
I have a pretty strange problem I can't seem to solve on my own.
My setup:
- Technicolor CGA2121 cable modem set to BRIDGE MODE
-> RT-AC86U
-> my various PCs (work perfect, full speed)
-> my Xboxes (360,X1X,XSX) (work perfect, full speed)
-> my Playstations (3,4,5) - THEY CAN'T EVEN CONNECT
Situation 1: With everything set to default, what happens is I get a WAN IP (dhcp) and everything works fine for a minute (even Playstation connectivity- then connection drops ("Your ISP'S DHCP does not function properly"). This is obviously unusable.
Situation 2: I set "Spoof LAN TTL value" in the WAN config and suddenly everything works and connection doesn't drop - but Playstation connectivity is borked ("failed" when checking internet access).
I have no idea what to do. At some point I managed to get PS connectivity up, but at sub 100kbit speeds, while everything else worked full speed.
The settings I played around with:
LAN -> IPTV -> enable multicast routing
WAN -> Extend the TTL value
Disable Firewall
I tried on official FW (RT-AC86U_3.0.0.4_386_40451-g30f1b6c) and on Merlin (RT-AC86U_384.19_0), same problem.
Before buying RT-AC86U, I was on TL-WR1043ND and everything just worked.
Any help would be greatly appreciated.
Apologies if I put this in the wrong forum, seemed like the best fit.
If you're blindly flashing back and forth between stock and RMerlin firmware, stop.
Flash the firmware you want on the router. Then follow the steps below to get it to a good/known state.
M&M Config https://www.snbforums.com/threads/n...l-and-manual-configuration.27115/#post-205573
Only change/add a customized configuration once the network has proven itself stable (several hours or days, if necessary).
I would further suggest following the suggestions below too.
Sanitize Network https://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
You can find more links (including the two above) in the link below.
L&LD | SmallNetBuilder Forums
Hi, thanks for the reply.
I only flashed once, after I exhausted everything I could (to the best of my ability) on the offical FW.
I checked your links, thanks, I appreciate it, but I was hoping for something more related to my very specific problem outlined above.
TLDR;
It seems my ISP needs "Spoof LAN ttl value" to even keep a connection for more than a minute (no idea how), but this causes every Playstation device to immediately lose the ability to connect.
I'll repeat for your benefit; flashing RMerlin firmware requires a full reset to factory defaults (and a minimal and manual configuration afterward).
Doing so allows the router's firmware to properly see and use the defaults it's expecting. Right now, this isn't happening.
Trying to troubleshoot 'your specific problem' is a wild goose chase at this point.
I understand, but the problem is present without any flashing at all.
Behaviour exhibited was out of the box.
Not sure what you're expecting me to do. I know flashing didn't cause this problem.
He's asking you to factory reset your firmware after installing Merlin. Without doing that any testing you do will be meaningless.
It's possible there is some sort of bug in the stock firmware that isn't present in Merlin, but it seems unlikely it would only be triggered by Sony products.
I went through the process last night.
For whatever reason, it still won't hold a connection to my ISP without spoofing TTL, and with that enabled none of my Playstation devices will connect through to the internet, wired or wireless.
Tried my old TL-WR1043ND and that worked fine.
So now I put a RT-AX55 behind the RT-AC86U and hooked up only my Playstations to that (I have many, so the testing was thorough) - and it works.
But now I have two routers, chained.
At least it works, while I continue trying to figure this out.
Edit: I just read this about my new PS5:
I assumed the problems started when I got my new router, but I did get the PS5 at the same time... Not sure why that would affect my PS4s and PS3s, but another thing to consider.
I'm sure nobody cares, but here's the epilogue of my problem.
I threw the ASUS out and bought a cheap old Archer C7 (TP-Link).
Immediately everything worked and all my problems resolved.
I can wire my Playstation machines directly now, no need to double NAT behind another router (TP link as well).
No special settings on the C7, just out of the box regular old config.
I do wish I figured out what this routers problem was, but alas, it's not in the cards.
I most certainly won't be buying an ASUS again, however.
Glad you solved your immediate issue. :)
You must be really dedicated to gaming if you trust TP-Link hardware/firmware to protect your network though.
Don't give up on Asus. You didn't even try to solve the issue you faced (at all).
Better hardware/software requires us to update our knowledge sometimes too. ;)
I do appreciate you following up and posting your solution. Wishing you all the best for Christmas and the New Year!
