[RT-AC87U running 384.5] WAN MAC change not taking
Sween
When I change the WAN MAC and apply settings, my RT-AC87U says that it is applied successfully and shows the different MAC; however, my modem doesn't issue a different IP address like it used to.
I switched to an old router running DD-WRT with a different WAN MAC, and my IP address did indeed change.
I regularly do this once every few months but just noticed since installing 384.5 my IP address is not changing when I change the WAN MAC, so this leads me to believe the WAN MAC address isn't actually changing on my RT-AC87U even though the setup page shows that it has. I did a factory reset and got the same result.
It`s possible the modem might be caching the MAC. Try rebooting it as well. Some ISPs will actually refuse to issue a new DHCP lease from a different MAC until the modem is kept offline for 5-10 minutes (that's the case for my own ISP).
I actually unplugged both the modem and router for about twenty minutes after I noticed it wasn't issued a new IP the first time.
When I tried the old DD-WRT router I had lying around, I didn't wait and was issued a new IP immediately. I also went into the DD-WRT settings and changed the WAN MAC after that and didn't wait any longer than it took to reboot the modem and got a different IP address again.
It's a strange problem that I've never encountered in all the years I've been doing that to get a different IP.
All I can say is last time I changed my WAN MAC through the Clone MAC page (as I wanted to reuse the same DHCP lease with a different router), it worked for me.
I appreciate your replies.
I might try re-flashing 384.5 or just wait for 384.7.
