RT-AC88U: CPU 2 on 100%
elgreco29
My second cpu is on 100%, Game Boost is deactivated. Here are the top-command. Last Merlin Build is installed. Any ideas? Thanks in Advance.
177172K used, 338012K free, 2444K shrd, 888K buff, 15508K cached
CPU: 1.5% usr 6.5% sys 0.0% nic 44.2% idle 47.4% io 0.0% irq 0.1% sirq
Load average: 9.04 9.00 8.39 2/134 19102
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
38 2 admin SW 0 0.0 1 3.7 [mtdblock3]
342 1 admin S 5508 1.0 1 0.4 sw_devled
289 1 admin R 2064 0.4 0 0.3 protect_srv
7767 7708 admin S 2012 0.3 0 0.2 sh /jffs/scripts/firewall banmalware
827 1 admin S 11004 2.1 1 0.1 /usr/sbin/lighttpd-arpping -f br0
427 1 admin S 5900 1.1 0 0.1 mastiff
825 1 admin S 13176 2.5 1 0.0 /usr/sbin/lighttpd -f /tmp/lighttpd.conf -D
425 1 admin S 10624 2.0 1 0.0 /usr/sbin/lighttpd-monitor
408 1 admin S 7824 1.5 1 0.0 networkmap --bootwait
336 1 admin S 6848 1.3 1 0.0 httpd -i br0
1194 1 admin S 6088 1.1 1 0.0 /usr/sbin/smbd -D -s /etc/smb.conf
583 1 admin S 5956 1.1 1 0.0 amas_lib
816 583 admin S 5956 1.1 0 0.0 amas_lib
645 643 admin S 5900 1.1 0 0.0 mastiff
643 427 admin S 5900 1.1 1 0.0 mastiff
644 643 admin S 5900 1.1 0 0.0 mastiff
1193 1 admin S 5868 1.1 1 0.0 nmbd -D -s /etc/smb.conf
335 1 admin S 5860 1.1 1 0.0 httpds -s -i br0 -p 8443
1 0 admin S 5552 1.0 0 0.0 /sbin/preinit
341 1 admin S 5516 1.0 1 0.0 watchdog
281 1 admin S 5512 1.0 1 0.0 /sbin/wanduck
1595 1 admin S 5508 1.0 0 0.0 bwdpi_wred_alive
477 1 admin S 5508 1.0 1 0.0 erp_monitor
679 1 admin S 5508 1.0 0 0.0 ntp
6099 1 admin S 5508 1.0 1 0.0 pc_block
850 1 admin S 5508 1.0 0 0.0 usbled
1078 1 admin S 5508 1.0 0 0.0 disk_monitor
429 1 admin S 5508 1.0 1 0.0 hour_monitor
428 1 admin S 5508 1.0 0 0.0 bwdpi_check
302 1 admin S 5508 1.0 0 0.0 wpsaide
184 1 admin S 5504 1.0 0 0.0 console
309 1 admin D 5212 1.0 1 0.0 nt_center
318 309 admin S 5212 1.0 1 0.0 nt_center
320 318 admin S 5212 1.0 0 0.0 nt_center
20073 1 admin S 5052 0.9 1 0.0 /etc/openvpn/vpnserver1 --cd /etc/openvpn/server1 --config config.ovpn
354 306 admin S 5048 0.9 1 0.0 nt_monitor
307 306 admin S 5048 0.9 0 0.0 nt_monitor
288 1 admin S 5048 0.9 1 0.0 nt_monitor
306 288 admin S 5048 0.9 0 0.0 nt_monitor
9378 1 admin D 4548 0.8 0 0.0 /jffs/.wtfast/bin/wtfd -d
685 684 admin S 3912 0.7 1 0.0 cfg_server
684 524 admin S 3912 0.7 0 0.0 cfg_server
524 1 admin S 3912 0.7 1 0.0 cfg_server
5533 429 admin D 3696 0.7 0 0.0 TrafficAnalyzer -e
340 1 admin S 3168 0.6 1 0.0 sysstate
1606 1605 admin S 3124 0.6 1 0.0 wred -B
1604 1 admin S 3124 0.6 1 0.0 wred -B
1782 1605 admin S 3124 0.6 0 0.0 wred -B
1783 1605 admin S 3124 0.6 0 0.0 wred -B
1778 1605 admin S 3124 0.6 1 0.0 wred -B
1777 1605 admin S 3124 0.6 0 0.0 wred -B
1780 1605 admin S 3124 0.6 0 0.0 wred -B
1779 1605 admin S 3124 0.6 0 0.0 wred -B
1776 1605 admin S 3124 0.6 1 0.0 wred -B
1781 1605 admin S 3124 0.6 0 0.0 wred -B
1605 1604 admin S 3124 0.6 1 0.0 wred -B
346 1 admin S 2884 0.5 1 0.0 rstats
871 851 admin S 2508 0.4 1 0.0 u2ec
'Last RMerlin build' doesn't help. Are you using the release or one of the Alpha builds? Please be specific.
When was the last time you rebooted your router (via the GUI)?
Last stable build. It looks like skynet has a locked process. Uninstall failed. I think a reboot could help, but i'm not next to mine router.
That happened after i tried to uninstall skynet. If i tried once more nothing happens.
Router Model; RT-AC88U
Skynet Version; v6.8.4 (27/03/2019) (d44e095d7dbcf1946be09ced53b4367f)
iptables v1.4.15 - (ppp0 @ 192.168.1.1)
ipset v6.32, protocol version: 6
IP Address; (217.233.98.43)
FW Version; 384.10_2 (Apr 3 2019) (2.6.36.4brcmarm)
Install Dir; /tmp/mnt/ASUS/skynet (56.2G / 57.6G Space Available)
SWAP File; /tmp/mnt/ASUS/myswap.swp (1.0G)
Boot Args; /jffs/scripts/firewall start skynetloc=/tmp/mnt/ASUS/skynet
Cron Jobs | [Failed]
IPSets | [Failed]
IPTables Rules | [Failed]
Select Menu Option:
[1] --> Unban
[2] --> Ban
[3] --> Banmalware
[4] --> Whitelist
[5] --> Import IP List
[6] --> Deport IP List
[7] --> Save
[8] --> Restart Skynet
[9] --> Temporarily Disable Skynet
[10] --> Update Skynet
[11] --> Settings
[12] --> Debug Options
[13] --> Stats
[14] --> Install Skynet
[15] --> Uninstall
[r] --> Reload Menu
[e] --> Exit Menu
A reboot via the GUI is preferred. Also, 384.10_2 is installed then?
Why do you need to be next to the router to reboot?
Because there is a german Gigaset Box connected and i remarked, that a hard reset is better for this device. With soft reboot often the connection to the voip-server failed. I don't know why. 3.84.10_2 is still installed.
Do you have a USB drive installed? Media files? If so, one or more may be corrupt, or, it may just be the capacity of the drive that is an issue too.
