128bit
just installed a new ax-86u. all seems well with the latest fw BUT there's one very odd behavior. when using file explorer (win10), i can see the router but not the nas. here's the rub, the nas is available and accessible to all wireless devices - laptops, tv, and receivers but it does not show up on the wired win 10 pc. i may need to put a laptop on a wire to see if i can dup this behavior but before that, i wanted to reach out.
some background. for the last 4 years, i run that same exact nas device as a usb 3 on my ac86u without problems on all devices. i've manually configured the ax86u and did not port the config file from the ac86u. to the best of my knowledge, everything else works fine though, the ax86u did not improve on range vs the ac86u. all my devices are wifi 5 or earlier and connect fine. ax mode is disabled on the ax86u.
