I'm on RT-AX86U with latest Merling firmware 3004.388.9_2 and I'm having an issue.
As per the title, any new VPN Director Rules don't save. I have around 20 active ones that are working fine. If I try to add a new one, it's added to the table after I create it, but then when I click apply, it disappears.
My logs are flooded with the following, but no mention of the new rule creation failure:
I've done some research, but my jfss partition seems to be healthy:
Any help is appreciated
Thanks!
Jun 6 19:00:01 kernel: jffs2: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Jun 6 19:00:01 kernel: jffs2: jffs2_reserve_space_gc of 196 bytes for garbage_collect_dnode failed: -28
Jun 6 19:00:01 kernel: jffs2: Error garbage collecting node at 001fc298!
XXXX@RT-AX86U-9E48:/tmp/home/root# ls -l /jffs/.sys/TrafficAnalyzer/ -ah
drw-rw-rw- 2 XXXX root 0 Apr 7 01:00 .
drw-rw-rw- 8 XXXX root 0 Mar 1 2023 ..
-rw-rw-rw- 1 XXXX root 4.4M Apr 7 01:00 TrafficAnalyzer.db
XXXX@RT-AX86U-9E48:/tmp/home/root# df -h
Filesystem Size Used Available Use% Mounted on
ubi:rootfs_ubifs 77.7M 71.5M 6.2M 92% /
devtmpfs 455.9M 0 455.9M 0% /dev
tmpfs 456.0M 488.0K 455.6M 0% /var
tmpfs 456.0M 4.6M 451.5M 1% /tmp/mnt
ubi1:data 4.5M 80.0K 4.1M 2% /data
/dev/mtdblock9 47.0M 34.4M 12.6M 73% /jffs
/dev/sda1 931.5G 831.4G 100.2G 89% /tmp/mnt/Seagate_Expansion_Drive
/dev/sdb2 5.5T 4.8T 647.8G 88% /tmp/mnt/Seagate_Backup_Plus_Drive
XXXX@RT-AX86U-9E48:/tmp/home/root# ls -l /jffs/.sys/nc/ -ah
drwxrwxrwx 2 XXXX root 0 Apr 6 14:22 .
-rw-r--r-- 1 XXXX root 36.0K Apr 6 14:22 nt_db.d
Thanks!
