adv3
Hi there,
iOS 13 drops the connection after a few seconds and unable to re-connect to wpa3 networks, even if the network is set to wpa3/2 mixed mode:
iOS 13.5.1
Apple's release notes https://www.apple.com/ios/ios-13/features/ said:
WPA3 Wi-Fi support
iOS supports the latest standard from Wi‑Fi Alliance to provide you with a more secure browsing experience.
Jun 10 02:19:09 acsd: eth7: selected channel spec: 0xe03a (52/80)
Jun 10 02:19:09 acsd: eth7: Adjusted channel spec: 0xe03a (52/80)
Jun 10 02:19:09 acsd: acs_set_chspec: 0xe03a (52/80) for reason APCS_INIT
Jun 10 02:19:15 WLCEVENTD: Auth F8:16:**:**:**:29
Jun 10 02:19:15 WLCEVENTD: ReAssoc F8:16:**:**:**:29
Jun 10 02:19:15 hostapd: eth7: STA f8:16:**:**:**:29 IEEE 802.11: associated
Jun 10 02:19:15 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Jun 10 02:19:15 hostapd: eth7: STA f8:16:**:**:**:29 RADIUS: starting accounting session 20FA043F4816A9FD
Jun 10 02:19:15 hostapd: eth7: STA f8:16:**:**:**:29 WPA: pairwise key handshake completed (RSN)
Jun 10 02:19:15 dnsmasq-dhcp[14164]: DHCPREQUEST(br0) 172.100.1.207 f8:16:**:**:**:29
Jun 10 02:19:15 dnsmasq-dhcp[14164]: DHCPACK(br0) 172.100.1.207 f8:16:**:**:**:29 laptop
Jun 10 02:19:15 WLCEVENTD: Deauth_ind F8:16:**:**:**:29
Jun 10 02:19:15 hostapd: eth7: STA f8:16:**:**:**:29 IEEE 802.11: disassociated
Jun 10 02:19:16 WLCEVENTD: Auth F8:16:**:**:**:29
Jun 10 02:19:16 WLCEVENTD: Assoc F8:16:**:**:**:29
Jun 10 02:19:16 hostapd: eth7: STA f8:16:**:**:**:29 IEEE 802.11: associated
Jun 10 02:19:16 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Jun 10 02:19:16 hostapd: eth7: STA f8:16:**:**:**:29 RADIUS: starting accounting session E7A12E48E9F3162F
Jun 10 02:19:16 hostapd: eth7: STA f8:16:**:**:**:29 WPA: pairwise key handshake completed (RSN)
Jun 10 02:19:16 dnsmasq-dhcp[14164]: DHCPREQUEST(br0) 172.100.1.207 f8:16:**:**:**:29
Jun 10 02:19:16 dnsmasq-dhcp[14164]: DHCPACK(br0) 172.100.1.207 f8:16:**:**:**:29 laptop
Jun 10 02:19:17 WLCEVENTD: Auth DC:A9:**:**:**:B9
Jun 10 02:19:18 WLCEVENTD: Auth 78:67:**:**:**:C9
Jun 10 02:19:30 WLCEVENTD: Deauth_ind DC:A9:**:**:**:B9
Jun 10 02:19:34 WLCEVENTD: Deauth_ind 78:67:**:**:**:C9
Jun 10 02:19:43 WLCEVENTD: Deauth_ind DC:A9:**:**:**:B9
Jun 10 02:19:50 WLCEVENTD: Auth 98:3B:**:**:**:5E
Jun 10 02:19:50 WLCEVENTD: Assoc 98:3B:**:**:**:5E
Jun 10 02:19:50 hostapd: eth7: STA 98:3b:**:**:**:5e IEEE 802.11: associated
Jun 10 02:19:50 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Jun 10 02:19:50 hostapd: eth7: STA 98:3b:**:**:**:5e RADIUS: starting accounting session 7AA3F46279F57665
Jun 10 02:19:50 hostapd: eth7: STA 98:3b:**:**:**:5e WPA: pairwise key handshake completed (RSN)
Jun 10 02:19:50 dnsmasq-dhcp[14164]: DHCPREQUEST(br0) 172.100.1.205 98:3b:**:**:**:5e
Jun 10 02:19:50 dnsmasq-dhcp[14164]: DHCPACK(br0) 172.100.1.205 98:3b:**:**:**:5e **
Jun 10 02:19:51 WLCEVENTD: Deauth_ind 78:67:**:**:**:C9
Jun 10 02:19:57 WLCEVENTD: Deauth_ind DC:A9:**:**:**:B9
Jun 10 02:20:11 WLCEVENTD: Deauth_ind DC:A9:**:**:**:B9
Jun 10 02:20:13 WLCEVENTD: Deauth_ind 78:67:**:**:**:C9
Jun 10 02:20:21 WLCEVENTD: Deauth_ind DC:A9:**:**:**:B9
Jun 10 02:20:40 WLCEVENTD: Deauth_ind 78:67:**:**:**:C9
Jun 10 02:20:41 WLCEVENTD: Deauth_ind DC:A9:**:**:**:B9
Jun 10 02:20:49 WLCEVENTD: Deauth_ind F8:16:**:**:**:29
iOS 13.5.1
WPA3 Wi-Fi support
