RT-AX88U AIMESH Issue
Cavey
Hello all,
Recently i purchased 3x RT-AX88U and 2 of them are in AIMESH mode. setup and all seems a breeze and all seems to be working, except for 1 RT-AX88U in AIMESH, the 2.4ghz light does not light up at all. only the 5ghz is lighted. i know i can reset the following to test if it is a faulty light but before that any thing i can do to trouble why this light does not light up? The other AIMESH router is fine.
When you include it in Aimesh it will factory reset anyway, why do you wait? Factory reset manually and if still failing return or RMA!
Hello Grisu,
Yup and that is what i did. Initially i had the impression that a 2rd AIMESH node works this way... since the routers may have seemed to be close by.. but when even the 8 port gigabit failed intermittently, i did RMA and the new unit seems to be working fine now.
Thanks again.
