RT-AX92U FTP doesn't show files in root of drive (dirs fine), smb fine
fancellu
Firmware: 3.0.0.4.386_43084-g728dd24
If I use the FTP server on the router, I cannot see files in the root of the drive
To be visible to the ftp it has to be in a folder.
I can transfer files to the root of the drive, via FTP, but they don't show to FTP after. They are v much there, as SMB sees them fine
Does the same whether I use WinSCP or command line FTP
Is this a known issue?
This is by design.
SMB only shows them when Allow guest login is enabled. Otherwise they're not visible.
I don't know why Asus designed it this way but it's always been like this.
Asus stores user configuration data at the root of the disk. You don't want to expose that to all users.
