RT-AX92U Wifi6 Across the Board
adelphiaUK
Recently, I had an issue connecting to my server (web and email) which in the end, turned out to be an issue with my host blocking my public IP.
However, prior to being informed as such, I thought it was a setting I had changed which was causing the issue.
So I backed up my settings thinking that checking that box about the password if it was to be shared, would remove the password.
After saving these settings, I went ahead and carried out a factory reset. All's well so far.
Anyway, now we come to post reset and I tried to load the configuration back in but once complete, it rebooted the router and low and behold, when it resumed it asked for a username and password which, of course, I didn't have as it wasn't the same as the one I was currently using.
Therefore, the settings file was no good to me and as a result, I had to do another reset.
Now comes the part I am stuck on. DHCP, port forwarding and all that is fine and dandy as I remember how to configure that.
What I cant remember is how to get WiFi6 across the board; 2.4 ghz, 5 ghz and 6 ghz. So please, could someone enlighten me as I know this router does it as that's what I had it set on before this escapade.
Thanking you in advance if you could tell me what settings I need to change, and where I find them to get this functionality back.
Chris
Please excuse misspellings and anything that may not make sense or cause offence as the medication I take can have an adverse effect on my mind.
This model doesn't have 6GHz radio. It has a single 5GHz-2 Wi-Fi 6 capable radio.
