POSSIBLE NEWS SCOOP - RT-BE86U details from ASUS rep at Computex Taipei
I went to Computex Taipei today and talked with an Asus rep there next to the Asus routers. Correct me if I am mistaken but I believe this is a news scoop because I couldn't find confirmed details of the RT-BE86U on any other site or thread. Here are the details the rep told me for the RT-BE86U. No model of it was shown on the floor and there are no spec sheets or flyers because apparently Asus is still working on it, so consider this entirely word of mouth.
RT-BE86U details
- It will have a Wi-Fi bandwidth (theoretical) of 6800 Mbps (i.e. a BE6800 class router)
- Will be tri-band (i.e. will have 2.4, 5, and 6 GHz) (NOTE - see edit below about possible lack of 6GHz)
- Slated to be launched in August 2024 or September 2024
- Likely will have 3 or 4 externally visible antennas
- Will have a Broadcom CPU (should be good news for Asuswrt-Merlin firmware fans including me)
- Ports will likely be 10GbE WAN, 4x 2.5Gbe LAN
- Pricing is unconfirmed but rep said to expect it to be in the ballpark of the AX86U (launch price presumably)
- Note that the rep said some details might change but the rep said it's definitely coming this year. Maybe the model number might be slightly different at launch. Who knows. I specifically asked if "the BE86U" is coming and those are the details the rep gave me
That's all I could get on the RT-BE86U. Seems to be very similar to the RT-BE92U, but with a lower theoretical throughput speed and possibly one fewer external antenna.
The models on the floor were the TUF-BE3600, RT-BE58U, RT-BE92U (BE9700 tri-band router), and RT-BE88U (BE7200 dual-band router). These 4 are likely to launch in the second half of 2024 Details for these can be found on plenty of other sites.
Personally, I am intrigued. I hope this is the worthy successor to the AX86U that a lot of us have been waiting for.
Edit 7/14/2024 - a recent FCC filing (https://www.snbforums.com/threads/r...-taipei-possible-news-scoop.90473/post-917560) shows apparently this model will not have 6GHz. If this is indeed the case, I apologize for the incorrect information.
RT-BE86U details
