Release RT-BE92U Firmware Firmware version 3.0.0.6_102_37523-g25e34fa_1096-gff526 03/27/2025
Still cant run two of these in ai-mesh with out the mesh node falling over every hour :(
Did you try the latest firmware in this thread? https://www.snbforums.com/threads/asus-rt-be92u-firmware-version-3-0-0-6-102_37563.95067/. Also might want to do a hard reset with the WPS button after the update on both units to make sure of a clean start.
1. Power off the router
2. While holding the WPS button power on router, and wait for the power LED to turn off
3. Release WPS button and power on the router, continue with a clean configuration
4. Repeat the above steps for both routers, as you said you have two of the same model.
will give it a go - i did do a normal reset just no the wps method.
Hopefully that will help. I did the reset several times, and made sure I was up to date on firmware before getting rid of this router after I encountered the issues, I wasn't able to resolve.
nope, the main router is now stable and my connecting be-88 and if mesh an ax-55 on it is stable..... but as soon as I replace the ax-55 with the second be92, it drops each hour or so.... Mesh is done by ethernet....
Well, if you ever decide to try different routers, if you can't get this setup stable, Someone mentioned on one of these firmware threads that the Zen WiFi 7 stable mesh system was more stable for mesh. Hopefully you won't have to go through all that to fix this, but putting it out there, so you can see if it's an option for you.
ill wait it out, i think. I can keep using my ax-55, good enough for a now just sad when you spend so much on a router. Asus never responds to feedback or tickets. I should have gone with another provider.
