RT-N65U problems when using transmission.
genera1
Need help setting up Transmission.
Got it working for a moment but it just keeps on crashing now. :/
Router n65u with 3.0.3.3-041
USB3 drive with ext3 with folder (transmission)
Transmission enabled under USB application port: 51413
Transmission client on OS X 10.8.2 checks of the port: 51413 as open. (gest error: Permission Denied to hdd/Transmission)
Could someone post the settings requierd so i can check the steps of? =D
What info would you need me to post?
Do you recommend another tool to handle the torrent>router drive?
You should mention which firmware you are running, since the version number you posted is not from any existing Asus firmware.
This is the Padavan firmware. That will help people answer your questions now that they know what firmware you are running.
No idea personally, I don't have a router compatible with that firmware.
Ok, this is starting to get silly!
I´m back on ASUS RT-N65U Firmware Version 3.0.0.4.342.
And i have tried my utterly best to get it working...
Seems to be poor stability with just n65u, is n56u more stable?
Have a chance to go back and change the router at the shop. Can you recommend one that actually works as upnp media server And has download support?
