Solved RT-N66 LEDs
wh7qq
John's Fork used to have an option to disable the system LEDs in the Administration>System page under WPS Button Behavior. That seems to have moved or been deleted. Is it somewhere else or is it just my failing eyesight?
Is it under Tools - Other Settings > Miscellaneous Options > Stealth Mode (disable all LEDs)
Exactly as you said. Thanks Colin. Was going by an older post from Merlin. There is also a setting to disable all but the power LED and that is what I wanted...all those bright blue LEDS on at once was too much.
