Sorry, I meant that I was only getting 100 Mbit/s when I was getting 1000 Mbit/s in version 378.56_2. I have tried power cycling the router but haven't done a 30/30/30 reset yet, may try that later tonight and report back. I'm unaware of any other features not functioning properly or any logs to reference.What do you mean by "Gigabit ethernet not functioning correctly"?
Have you tried reset your AP and try again?
Is there any error message or system log can be reference?
It is enabled.First,look under Tools-Sysinfo if HW acceleration is enabled
It's still set for 100 :/ should I just flash an earlier version?On asus routers =*Turn off the router, press the WPS button, then turn on the router. Wait about 10 seconds, then release the WPS button.
I feel like such an idiot. I just tested the connection by bringing in a gigabit switch that will light up orange for 100 and green for 1000 and of course it lit up green so I just use some compressed air to clean it out and made sure the cable was seated all the way in. Thanks for the help everyone.Link rate is negotiated at connect time. If the Ethernet cable isn't good enough, then the switch will negotiate a lower speed. There is no configuration on the router that can affect that.
Change your cable, and make sure the other device is also properly configured to auto-negotiate (and that it does support Gigabit).
| Thread starter | Title | Forum | Replies | Date |
| R | Asus RT N66u running Asuswrt Merlin change VPN listening port from WAN to LAN | Asuswrt-Merlin | 7 |
Welcome To SNBForums
