RT-N66U - can't enable 5g
hoaxci5
I've tried stock firmware and merlin(current and old) and for some reason can't get 5g to enable anymore.
It says it is on under the general settings, and with the merlin builds it says disabled on the little status icon.
The light on the router itself is not on. Any help to get it re enabled?
As I've been working on my fork, I've had this happen to me when I accidently mucked up (technical term :)) some of the wireless nvram parameters. First thing to try would be to either restore a known good backup .CFG file or do a factory reset and reconfigure.
