RT-N66U Disable Wi-Fi
wegl
Hello
In Wireless - Professional i disable 2.4 Ghz but i can't disable 5 Ghz.
In Band list box only 5GHz. And when i apply "Enable radio NO" Nothing happens.
Firmware 378.55 by Merlin
The query is a bit confusing.
You mentioned that you are able to disable 2.4 Ghz but cannot disable/see 5 Ghz.
Then again you mention that 5 GHZ is only available in band list which means 2.4 ghz is not availalble.
Even I am on 378.55 from Merlin on RTN66U and have no issues with both bands.
For clarity:
1. Can you see in the drop down list both 2.4 & 5 Ghz bands?
2. What bands are available in your band drop down list?
3. Router model ?
4. Factory reset after flashing firmware ?
1) only 5 GHz
2) available 5Ghz in Wireless General and in Professional
3) ASUS RT-N66U
4) yes factory reset and after flashing original asus firmware showing only 5GHz
When apply Enable on Band 5Ghz enable 2.4 band. I can't disable 5Ghz band.
1) only 5 GHz
3) ASUS RT-N66U
Can you check the System Log for the below
Jan 1 05:30:08 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Jan 1 05:30:08 kernel: wl_module_init: passivemode set to 0x0
Jan 1 05:30:08 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Jan 1 05:30:08 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 05:30:08 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Jan 1 05:30:08 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002
i.e., whether eth1 & eth2 are found and enabled
Jan 1 03:00:08 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Jan 1 03:00:08 kernel: wl_module_init: passivemode set to 0x0
Jan 1 03:00:08 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Jan 1 03:00:08 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 03:00:08 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Jan 1 03:00:08 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 03:00:08 kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Jan 1 03:00:08 kernel: br0: starting userspace STP failed, staring kernel STP
Jan 1 03:00:08 kernel: vlan1: dev_set_promiscuity(master, 1)
Jan 1 03:00:08 kernel: device eth0 entered promiscuous mode
Jan 1 03:00:08 kernel: device vlan1 entered promiscuous mode
Jan 1 03:00:08 kernel: device eth1 entered promiscuous mode
Jan 1 03:00:08 kernel: device eth2 entered promiscuous mode
When ENABLE band 5Ghz
Jul 23 15:45:19 rc_service: httpd 271:notify_rc set_wltxpower;restart_wireless
Jul 23 15:45:19 kernel: br0: port 2(eth2) entering disabled state
Jul 23 15:45:19 kernel: device eth2 left promiscuous mode
Jul 23 15:45:20 kernel: Hooks already unregistered
Jul 23 15:45:20 snooper: terminated with signal 15
Jul 23 15:45:20 kernel: vlan1: dev_set_allmulti(master, -1)
Jul 23 15:45:23 kernel: wl_module_init: passivemode set to 0x0
Jul 23 15:45:23 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jul 23 15:45:23 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jul 23 15:45:23 kernel: device eth1 entered promiscuous mode
Jul 23 15:45:23 kernel: br0: port 2(eth1) entering listening state
Jul 23 15:45:23 kernel: br0: port 2(eth1) entering learning state
Jul 23 15:45:23 kernel: br0: topology change detected, propagating
Jul 23 15:45:23 kernel: br0: port 2(eth1) entering forwarding state
Jul 23 15:45:23 kernel: device eth2 entered promiscuous mode
Jul 23 15:45:23 kernel: br0: port 3(eth2) entering listening state
Jul 23 15:45:23 kernel: br0: port 3(eth2) entering learning state
Jul 23 15:45:23 snooper: started on vlan1/br0
Jul 23 15:45:23 kernel: br0: port 3(eth2) entering forwarding state
Jul 23 15:45:23 kernel: vlan1: dev_set_allmulti(master, 1)
\\Disable in band list 5Ghz
Jul 23 15:50:22 rc_service: httpd 271:notify_rc set_wltxpower;restart_wireless
Jul 23 15:50:22 kernel: br0: port 2(eth1) entering disabled state
Jul 23 15:50:22 kernel: device eth1 left promiscuous mode
Jul 23 15:50:22 kernel: br0: port 3(eth2) entering disabled state
Jul 23 15:50:22 kernel: device eth2 left promiscuous mode
Jul 23 15:50:22 kernel: Hooks already unregistered
Jul 23 15:50:22 snooper: terminated with signal 15
Jul 23 15:50:22 kernel: vlan1: dev_set_allmulti(master, -1)
Jul 23 15:50:25 kernel: wl_module_init: passivemode set to 0x0
Jul 23 15:50:25 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jul 23 15:50:25 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jul 23 15:50:26 kernel: device eth2 entered promiscuous mode
Jul 23 15:50:26 kernel: br0: port 2(eth2) entering listening state
Jul 23 15:50:26 kernel: br0: port 2(eth2) entering learning state
Jul 23 15:50:26 kernel: br0: topology change detected, propagating
Jul 23 15:50:26 kernel: br0: port 2(eth2) entering forwarding state
Jul 23 15:50:26 snooper: started on vlan1/br0
Jul 23 15:50:26 kernel: vlan1: dev_set_allmulti(master, 1)
This sounds like an issue that was fixed a long time ago relating to some bad nvram settings. You said you did a factory reset after loading the code. Just to verify, that after the factory reset you reconfigured by hand and did not load a saved configuration (which would put the problem back).
It looks like both your bands 2.4 & 5 are getting recognized and are getting started.
Interesting from your logs that when you turn off 5 GHz, it turns off and then turns back again.
As mentiond in your \\Disable in band list 5Ghz comment.
The UI is messed up somehow and showing you only 1 band,
Maybe a bad flash/upgrade procedure.
Troubleshoot:
1. unmount and remove any usb devices from your router
2. Also disconnect any other camera's / hdd's / ip devices from the router
3. check if 5 ghz and 2.4 ghz led lights are ON your router
4. check if the 5 ghz and 2.4 ghz with ASUS default SSID or SSID set by you, are being broadcast, you can check with your desktop / phone / ipad etc.,
5. Just make sure the router is powered on and has Net connection from your ISP. (you can check the led's for guidance)
If you can see the 2.4 ghz led's turning on and see 2.4 ghz being broadcast from your router but not showing up on the GUI, then it was a firmware upgrade which went bad, reset to factory defaults and do the upgrade process again.
To verify John's theory, check the content of these two values, over SSH:
nvram get wl0_nband
nvram get wl1_nband
If either of them returns -1, then you have the corrupted value caused by a bug that was fixed a year ago. Try setting them as follow:
nvram set wl0_nband=2
nvram set wl1_nband=1
nvram commit
service restart_wireless
