O
Ormu
Guest
I was using RT-N66U yesterday (via Ethernet) and it was working fine. Today, 5GHz Wifi was unstable. After a few reconnections I logged into the router control panel and rebooted the router.
After rebooting, network was not working and the Wifi lights were off. The power led was blinking slowly, about 3sec on and 3sec off. The WAN led and one ethernet led were working normally. I rebooted the router twice using the power button but it didn't help.
I recalled that the power led may flash like that when the router is in the recovery mode. I connected my computer using ethernet and configured a manual IP address. Now the router responded to ping (with some packet loss) and I could indeed access the recovery panel.
I clicked the NVRAM reset link in the recovery panel and it displayed a message "Command nvram erase completed". After that I rebooted the router again using the power button.
After rebooting, the router was still in the recovery mode. I tried to reset it by using the reset button as well as using the WPS button while powering on the router but the router is still in the recovery mode.
I also tried to hold the reset button while powering on the router - this would normally put it into the recovery mode. It did not cause it to exit the recovery mode.
I'm going to upload the firmware using the recovery panel next. How long should it take? I've heard from various sources that it may take a minute, 10 to 15 minutes, up to an hour, 90 minutes or 4 hours. The current firmware is the latest official released by Asus.
If it doesn't work, I'm going to test the power supply as soon as I have access to suitable equipment. But I guess that's where it ends. Are there any other tricks I should try, or is it time to buy a new router? This router is about 7 and a half years old and it has been in 24/7 use for at least 5 years.
I also noticed that scanning port 80 when the router is in the recovery mode causes the recovery panel to stop responding, and the port also goes into stealth state. Is this intentional?
