RT_AC68U .48_1 samba issue
dabones
Since .48_1 i have a problem with samba, both USBs utilized, on USB3 a RAID system and on USB2 a 16Gb stick.
After a reboot Samba works fine, when trying to access the page through http (std user interface,192.168.1.1), the web interface directly locks up (got some strange message: Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-AC68U.
To access the settings of RT-AC68U, reconnect to the wireless network and use the updated IP address and port number.),
and Samba is not accessible anymore.
Also the 192.168.1.1 is not responding.
Looks like problem with RT-N16.
Does anybody know reason or fix, or should i revert to .47?
You need to try the .48_2 version for your router.
Reverted back to .47, and problem still exist.
Must be something with my two drives.
to be continued...
As mentioned, i have a RT-AC68U, there is no 48_2 version, only for the RT-N16.
Ooops, sorry, I saw RT-N16 and thought it was yours. :o
Removed the 16G etx4 USB-stick, problems are gone.
But I did not put it there for NO reason. I was trying to set-up my own website including Ownbox (for now). But thats a no go.
Still investigating where the problem lies.
To be continued....
Formatted a 32Gb USB stick etx4, and mounted it.
Still no problems.
Must be a problem with Optware...
Anyone, is there an alternative way to install a http server?
