Run my script as a daemon ?
miljbee
Hello,
I have written a script which should run permanently. Could you give me some advices on how to set my AC68U to start it up at boot ?
Ideally, I would like to be able to manage it with something like
service myscript start/stop/restart.
Thanks for your help.
One way is to install Entware (which is good to have by itself anyway).
Then make good use of init.d in Entware. Look at /opt/etc/init.d. Depends on your scripts, most likely you'll need helpers (which available from Entware as well). I've been doing this for years...happily.
Could you tell me which helpers I should consider ?
You can start with "daemonize" - a package available from Entware. "daemonize myscript.sh" as command line to run your script as daemon. For the init.d script, simply copy from an existing one. Then rename and adapt..
