ruTorrent v3.9 Some plugins don't works
elrengo
Hi!
I'm owner of RT-AC3100m using a asuswrt-merlin firmware (384.17) with Entware installed on WD 1TB USB3 HDD. On router I have installed ruTorrent 3.9 and Diversion.
Today when I require to create a torrent I found in the following errors in logs tab:
[03.07.2020 08:51:01] WebUI started.
[03.07.2020 08:51:02] rTorrent user can't access 'id' program. Some functionality will be unavailable.
[03.07.2020 08:51:02] rTorrent user can't access 'stat' program. Some functionality will be unavailable.
[03.07.2020 08:51:02] mediainfo: Plugin will not work. rTorrent user can't access external program (mediainfo).
[03.07.2020 08:51:02] _task: Plugin will not work. rTorrent user can't access external program (php).
[03.07.2020 08:51:02] trafic: Plugin will not work. rTorrent user can't access external program (php).
[03.07.2020 08:51:02] history: Plugin will not work. rTorrent user can't access external program (php).
[03.07.2020 08:51:02] unpack: Plugin will not work. rTorrent user can't access external program (php).
[03.07.2020 08:51:02] create: Plugin will not work. rTorrent user can't access external program (php).
[03.07.2020 08:51:02] _task: Plugin will not work. rTorrent user can't access external program (pgrep).
After enter to shell of the RT-AC3100 I can see both programs installed on my system:
pgrep
[/tmp/home/root]
[elrengo@RT-AC3100]#pgrep --help
Usage:
 pgrep [options] <pattern>
Options:
 -d, --delimiter <string>  specify output delimiter
 -l, --list-name           list PID and process name
 -a, --list-full           list PID and full command line
 -v, --inverse             negates the matching
 -w, --lightweight         list all TID
 -c, --count               count of matching processes
 -f, --full                use full process name to match
 -g, --pgroup <PGID,...>   match listed process group IDs
 -G, --group <GID,...>     match real group IDs
 -i, --ignore-case         match case insensitively
 -n, --newest              select most recently started
 -o, --oldest              select least recently started
 -P, --parent <PPID,...>   match only child processes of the given parent
 -s, --session <SID,...>   match session IDs
 -t, --terminal <tty,...>  match by controlling terminal
 -u, --euid <ID,...>       match by effective IDs
 -U, --uid <ID,...>        match by real IDs
 -x, --exact               match exactly with the command name
 -F, --pidfile <file>      read PIDs from file
 -L, --logpidfile          fail if PID file is not locked
 --ns <PID>                match the processes that belong to the same
                           namespace as <pid>
 --nslist <ns,...>         list which namespaces will be considered for
                           the --ns option.
                           Available namespaces: ipc, mnt, net, pid, user, uts
 -h, --help     display this help and exit
 -V, --version  output version information and exit
For more details see pgrep(1).
[/tmp/home/root]
PHP
[/tmp/home/root]00]#
[elrengo@RT-AC3100]#opkg upgrade
Upgrading opkg on root from 2019-06-14-dcbc142e-2 to 2020-05-07-f2166a89-1...
Downloading http://bin.entware.net/armv7sf-k2.6/opkg_2020-05-07-f2166a89-1_armv7-2.6.ipk
Upgrading zoneinfo-europe on root from 2019c-1 to 2020a-1...
Downloading http://bin.entware.net/armv7sf-k2.6/zoneinfo-europe_2020a-1_armv7-2.6.ipk
Upgrading mediainfo on root from 19.09-1 to 20.03-1...
Downloading http://bin.entware.net/armv7sf-k2.6/mediainfo_20.03-1_armv7-2.6.ipk
Upgrading bash on root from 5.0-3 to 5.0-4...
Downloading http://bin.entware.net/armv7sf-k2.6/bash_5.0-4_armv7-2.6.ipk
Upgrading libcurl on root from 7.69.0-1 to 7.70.0-1...
Downloading http://bin.entware.net/armv7sf-k2.6/libcurl_7.70.0-1_armv7-2.6.ipk
Upgrading mc on root from 4.8.23-2 to 4.8.24-1...
Downloading http://bin.entware.net/armv7sf-k2.6/mc_4.8.24-1_armv7-2.6.ipk
Upgrading php7-cgi on root from 7.4.3-1 to 7.4.6-1...
Downloading http://bin.entware.net/armv7sf-k2.6/php7-cgi_7.4.6-1_armv7-2.6.ipk
Upgrading zoneinfo-asia on root from 2019c-1 to 2020a-1...
Downloading http://bin.entware.net/armv7sf-k2.6/zoneinfo-asia_2020a-1_armv7-2.6.ipk
Upgrading coreutils on root from 8.31-1 to 8.32-1...
Downloading http://bin.entware.net/armv7sf-k2.6/coreutils_8.32-1_armv7-2.6.ipk
Upgrading coreutils-stat on root from 8.31-1 to 8.32-1...
Downloading http://bin.entware.net/armv7sf-k2.6/coreutils-stat_8.32-1_armv7-2.6.ipk
Upgrading libmbedtls on root from 2.16.5-1 to 2.16.6-1...
Downloading http://bin.entware.net/armv7sf-k2.6/libmbedtls_2.16.6-1_armv7-2.6.ipk
Removing obsolete file /opt/lib/libmbedx509.so.2.16.5.
Removing obsolete file /opt/lib/libmbedcrypto.so.2.16.5.
Removing obsolete file /opt/lib/libmbedtls.so.2.16.5.
Upgrading nmap on root from 7.70-2 to 7.80-2...
Downloading http://bin.entware.net/armv7sf-k2.6/nmap_7.80-2_armv7-2.6.ipk
Upgrading php7-mod-json on root from 7.4.3-1 to 7.4.6-1...
Downloading http://bin.entware.net/armv7sf-k2.6/php7-mod-json_7.4.6-1_armv7-2.6.ipk
Upgrading curl on root from 7.69.0-1 to 7.70.0-1...
Downloading http://bin.entware.net/armv7sf-k2.6/curl_7.70.0-1_armv7-2.6.ipk
Upgrading libstdcpp on root from 8.3.0-9 to 8.4.0-9...
Downloading http://bin.entware.net/armv7sf-k2.6/libstdcpp_8.4.0-9_armv7-2.6.ipk
Upgrading coreutils-id on root from 8.31-1 to 8.32-1...
Downloading http://bin.entware.net/armv7sf-k2.6/coreutils-id_8.32-1_armv7-2.6.ipk
Upgrading libgcc on root from 8.3.0-9 to 8.4.0-9...
Downloading http://bin.entware.net/armv7sf-k2.6/libgcc_8.4.0-9_armv7-2.6.ipk
Upgrading libffi on root from 3.2.1-4 to 3.3-2...
Downloading http://bin.entware.net/armv7sf-k2.6/libffi_3.3-2_armv7-2.6.ipk
Removing obsolete file /opt/lib/libffi.so.6.
Removing obsolete file /opt/lib/libffi.so.6.0.4.
Upgrading php7 on root from 7.4.3-1 to 7.4.6-1...
Downloading http://bin.entware.net/armv7sf-k2.6/php7_7.4.6-1_armv7-2.6.ipk
Upgrading libssp on root from 8.3.0-9 to 8.4.0-9...
Downloading http://bin.entware.net/armv7sf-k2.6/libssp_8.4.0-9_armv7-2.6.ipk
Upgrading procps-ng on root from 3.3.15-4 to 3.3.15-5...
Downloading http://bin.entware.net/armv7sf-k2.6/procps-ng_3.3.15-5_armv7-2.6.ipk
Upgrading libtirpc on root from 1.2.5-2 to 1.2.6-1...
Downloading http://bin.entware.net/armv7sf-k2.6/libtirpc_1.2.6-1_armv7-2.6.ipk
Upgrading libopenssl on root from 1.1.1d-2 to 1.1.1g-1...
Downloading http://bin.entware.net/armv7sf-k2.6/libopenssl_1.1.1g-1_armv7-2.6.ipk
Upgrading procps-ng-pgrep on root from 3.3.15-4 to 3.3.15-5...
Downloading http://bin.entware.net/armv7sf-k2.6/procps-ng-pgrep_3.3.15-5_armv7-2.6.ipk
Configuring libgcc.
Configuring libssp.
Configuring libopenssl.
Configuring libcurl.
Configuring libstdcpp.
Configuring coreutils.
Configuring coreutils-stat.
Configuring coreutils-id.
Configuring curl.
Configuring mediainfo.
Configuring opkg.
Configuring php7.
Configuring php7-mod-json.
Configuring zoneinfo-europe.
Configuring libtirpc.
Configuring libffi.
Configuring bash.
Configuring procps-ng.
Configuring procps-ng-pgrep.
Configuring libmbedtls.
Configuring mc.
Configuring php7-cgi.
Configuring zoneinfo-asia.
Configuring nmap.
[/tmp/home/root]
What happen? Can someone helpme? In the past works fine.
Thanks!
elrengo
With a service stop and start was restored the functionality.
