script missing line after reboot....
alienx2
im having problem with post-mount script. every reboot, it can run some lines but others lines are missing.
#!/bin/sh
if [ $1 = "/tmp/mnt/TOSHIBA" ]
then
  ln -nsf $1/entware /tmp/opt
fi
ln -s /tmp/mnt/TOSHIBA/entware/lib/python2.7/site-packages/pytz/zoneinfo/Asia/Manila /etc/localtime
sleep 5
service restart_dnsmasq
sleep 5
/opt/etc/init.d/S81aria2 start
/opt/etc/init.d/S75nzbget start
sleep 10
/opt/etc/init.d/S98headphones start
sleep 10
/opt/etc/init.d/S96sickbeard start
sleep 10
/opt/etc/init.d/S95nzbhydra start
sleep 10
swapon /opt/swap
sleep 12
wget -qO- "http://winhelp2002.mvps.org/hosts.txt" "http://someonewhocares.org/hosts/zero/hosts" "http://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&startdate[day]=&startdate[month]=&startdate[year]=&mimetype=plaintext&useip=0.0.0.0" | grep -w ^0.0.0.0 | sed $'s/\r$//' | sort -u > /tmp/mnt/TOSHIBA/Download/settings/DNS/hosts.clean
sleep 5
but missing lines:
What do you mean with missing lines? commands are not executed?
First, move "swapon /opt/swap" right after "fi"
fi
swapon /opt/swap
Also try to log commands
logger -st "$0" "Starting headphones..."
sleep 10
logger -st "$0" "Starting sickbeard..."
sleep 10
logger -st "$0" "Starting nzbhydra..."
Then look at router syslog
here:
Jan 26 16:39:26 dnsmasq[1204]: read /etc/hosts - 5 addresses
Jan 26 16:39:29 dnsmasq[1204]: read /tmp/mnt/TOSHIBA/Download/settings/DNS/hosts_manual.blocked - 78 addresses
Jan 26 16:39:29 dnsmasq[1204]: read /tmp/mnt/TOSHIBA/Download/settings/DNS/hosts.clean - 25432 addresses
Jan 26 16:39:29 dnsmasq[1204]: read /etc/hosts.dnsmasq - 7 addresses
Jan 26 16:39:29 dnsmasq-dhcp[1204]: read /etc/ethers - 9 addresses
Jan 26 16:39:29 dnsmasq[1204]: using nameserver 208.67.222.222#53 for domain local
Jan 26 16:39:29 dnsmasq[1204]: using nameserver 8.8.8.8#53 for domain local
Jan 26 16:39:29 dnsmasq[1204]: using nameserver 8.8.4.4#53
Jan 26 16:39:29 dnsmasq[1204]: using nameserver 84.200.70.40#53
Jan 26 16:39:29 dnsmasq[1204]: using nameserver 84.200.69.80#53
Jan 26 16:39:29 dnsmasq[1204]: using local addresses only for domain nas
Jan 26 16:39:31 /jffs/scripts/post-mount: Starting Aria2...
Jan 26 16:39:31 /jffs/scripts/post-mount: Starting NZBGet...
Jan 26 16:39:44 /jffs/scripts/post-mount: Starting headphones...
it didnt run well... but manual type run working fine.
in /opt/etc/init.d/S98headphones:
PATH=/opt/bin:/opt/sbin:$PATH
/opt/bin/python /opt/etc/headphones/Headphones.py -d
