The empty values for the queue mean that UNMAP was not properly applied to the device, even though the mode is set by the unmap script. I think it's either the enclosure or the SSD that isn't supported. I'll probably add an explicit error message for such cases to the script by checking these values.File systemp is ext4:
/dev/sda1 ext4 57431276 2203612 52280544 4% /tmp/mnt/SSD
cat /sys/block/sda/queue/discard_max_bytes
0
cat /sys/block/sda/queue/discard_granularity
0
Your drive reports proper values. What file system are you using? ext4?I have other values:
Code:➜ cat /sys/block/sda/queue/discard_max_bytes 4294966784 ➜ cat /sys/block/sda/queue/discard_granularity 4096
ssd_trim: ERROR: fstrim: FITRIM: Inappropriate ioctl for device
Yes:What file system are you using? ext4?
➜ mount | grep ssd
/dev/sda1 on /tmp/mnt/ssd type ext4 (rw,nodev,relatime)
➜ lsblk -D /dev/sda1
NAME DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO
sda1 0 4K 4G 0
This is the same as readingAccording to the link below a value greater than zero for DISC-MAX would mean that TRIM might be enabled?
discard_max_bytes directly from /sys/block, which we have already done.unmap, and you have discard_max_bytes > 0, but fstrim fails with FITRIM: Remote I/O error, which is different from FITRIM: Operation not supported. Basically, that means the discard command reaches the device, but the device or bridge fails while executing it. This looks like a buggy USB bridge (or firmware) that claims unmap but doesn't handle it correctly.discard_max_bytes = 0 simply indicate that TRIM is not supported.fstrim -v -o 4096 -l $((1024*1024)) /tmp/mnt/ssd
Result:I have one more idea for you to check - try trimming just 1 MB:
Code:fstrim -v -o 4096 -l $((1024*1024)) /tmp/mnt/ssd
➜ fstrim -v -o 4096 -l $((1024*1024)) /tmp/mnt/ssd
/tmp/mnt/ssd: 0 bytes trimmed
What did you change to make it start working? Did you modifyTRIM initially did not work for the same HW combo on my Raspberry Pi 4 B either, but using these instructions I got it to work on that platform:
Enabling TRIM on an external SSD on a Raspberry Pi
I've been doing a lot of benchmarking and testing with the Raspberry Pi 4 and SSDs connected via USB. I explored UASP Support, which USB SSDs are the fastest, and I'm now booting my Pis from USB SSDs. Anyways, one thing that I have wondered about—and some people have asked me about—is TRIM...www.jeffgeerling.com
Do we have similar tools for our ASUS routers?
discard_max_bytes to a custom value? Based on the output of the fstrim command set to 1 MB, TRIM reaches your disk, but it probably doesn’t know the correct number of bytes (the default may be wrong) and fails.fstrim, similar to the "Enabling TRIM" section in the tutorial.I first had to change the provisioning mode fromWhat did you change to make it start working? Did you modifydiscard_max_bytesto a custom value?
full to unmap, but I indeed also had to modify discard_max_bytes to a non-default value. I had to set discard_max_bytes to a multiple of discard_granularity, as Tom suggested in the comments. Using a corrected version of his script, the value for my HW combo apparently is 33550336, but I don't know how to try/set it on the router as well.Duplicate thisHow to set up the SSD trim for multiple drives?
pre-mount block per device for unmap, specifying a different per-drive SSD_VOLUME_LABEL each time:SSD_VOLUME_LABEL_1='ssd1'
SSD_VOLUME_LABEL_1='ssd2'
if tune2fs -l "$1" 2>/dev/null |
grep -q "Filesystem volume name: *$SSD_VOLUME_LABEL_1$";
then
/jffs/scripts/ssd/ssd_unmap.sh # specify your Vendor ID here
fi
grep -q "Filesystem volume name: *$SSD_VOLUME_LABEL_2$";
then
fi
services-start per every device:cru a trim_ssd_1 "0 4 * * 0 /jffs/scripts/ssd/ssd_trim.sh ssd1"
cru a trim_ssd_2 "0 4 * * 0 /jffs/scripts/ssd/ssd_trim.sh ssd2"
Simply add this line to yourI first had to change the provisioning mode from full to unmap, but I indeed also had to modify discard_max_bytes to a non-default value. I had to set discard_max_bytes to a multiple of discard_granularity, as Tom suggested in the comments. Using a corrected version of his script, the value for my HW combo apparently is 33550336, but I don't know how to try/set it on the router as well.
ssd_unmap.sh:echo <YOUR_VALUE> > /sys/block/sda/queue/discard_max_bytes
sda is not guaranteed if you have multiple USB devices attached, in that case you need to figure it out dynamically./sys/block/sda/queue/discard_max_bytes and now it seems to work?! ➜ echo 33550336 > /sys/block/sda/queue/discard_max_bytes
➜ ./ssd_trim.sh ssd
ssd_trim: Running fstrim on /tmp/mnt/ssd...
ssd_trim: /opt/sbin/fstrim succeeded: /tmp/mnt/ssd: 243424014336 bytes trimmed
➜ ./ssd_trim.sh ssd
ssd_trim: /opt/sbin/fstrim succeeded: /tmp/mnt/ssd: 0 bytes trimmed
Yes, that's correct.Only needed to change/sys/block/sda/queue/discard_max_bytesand now it seems to work?!![]()
discard_granularity is 4096? I'm curious if it would work.echo 4294963200 > /sys/block/sda/queue/discard_max_bytes
cat /sys/block/sda/queue/discard_max_hw_bytes
cat /sys/block/sda/queue/logical_block_size
cat /sys/block/sda/queue/write_same_max_bytes
➜ cat /sys/block/sda/queue/discard_max_hw_bytes
4294966784
➜ cat /sys/block/sda/queue/logical_block_size
512
➜ cat /sys/block/sda/queue/write_same_max_bytes
33550336
➜ echo 4294963200 > /sys/block/sda/queue/discard_max_bytes
➜ /jffs/scripts/ssd/ssd_trim.sh ssd
ssd_trim: ERROR: fstrim: FITRIM: Remote I/O error
CUSTOM_V6_IPSETS='
blk6:
https://www.team-cymru.org/Services/Bogons/fullbogons-ipv6.txt
https://www.spamhaus.org/drop/dropv6.txt
# Uncomment the URLs below for enhanced protection;
# Replace YOUR_API_KEY for AbuseIPDB
# https://api.abuseipdb.com/api/v2/blacklist -d plaintext -d ipVersion=6 -H "Key: YOUR_API_KEY"
WAN_FW_V6_RULES='
# General IPv6 inbound blocking
block:any:any:blk6
# Block all incoming IPv6 web traffic from China (HTTP 2/3)
block:443:udp:cn6
block:80,443:tcp:cn6
# 1. Excluded interfaces for SDN IPv6 auto-assignment
# * Lists bridge interfaces that should be skipped when assigning IPv6 /64 subnets.
# * Useful if you want to keep certain SDNs IPv4-only, or manage their IPv6 configuration manually.
# * The main LAN (br0) is always excluded automatically, so it should not be listed here.
# Example:
# EXCLUDED_IFACES='br54 br56'
EXCLUDED_IFACES=''
# STATIC_ROUTE_RULES - one rule per line: iface|link_local|static_route
# Syntax (no spaces; comments allowed with "#", blank lines ignored):
# <iface>|<link_local>|<static_route>
# Fields:
# iface - router interface that reaches the target host (e.g., br0, br52).
# link_local - link-local address of the target host on that interface (must be fe80::/10).
# Do NOT append "/64" here - it's a single address, not a prefix.
# static_route - IPv6 subnet to be routed to that host (typically a /64 carved from your /56).
# Tips:
# * Find the host's link-local address on the host itself:
# ip -6 addr show dev <iface>
# * Multiple rules are supported; each will be validated and applied independently.
# * Example carving /64 subnets from 2a10:abcd:1234:aa00::/56:
# br0|fe80::1234:56ff:fe78:9abc|2a10:abcd:1234:aa10::/64
# br0|fe80::1234:56ff:fe78:9abc|2a10:abcd:1234:aa20::/64
# Note:
# Avoid using the first few subnets from your delegated prefix if you also use the
# sdn_v6_br.sh script for SDN IPv6 configuration. That script automatically assigns
# the earliest /64s (starting from index 0) to SDN bridges, so using the same ranges
# for static routes may cause prefix conflicts.
STATIC_ROUTE_RULES='
This release brings full IPv6 support to the IPSet-based WAN Firewall and extends IPv6 functionality in the Asus firmware in several areas
Network-related scripts are IPv4-only since my ISP doesn't support IPv6 yet. I'll add IPv6 support once I can properly test it.
sdn_v6_dnsmasq.sh - enable IPv6 RA and SLAAC for Asuswrt-Merlin SDN dnsmasq instances
pre-mount hook and ssd_unmap.sh are no longer needed - all provisioning mode and UNMAP logic is now built into the main script. It's also no longer necessary to pass the disk label as an argument.EXCLUDED_SSD_LABELS in config.sh.discard_max_bytes value, saves it to nvram if successful, and permanently marks the device as unsupported (in nvram) if it cannot be made to work reliably.kuchkovsky@rt:/tmp/home/root# /jffs/scripts/ssd/ssd_trim.sh
ssd_trim: Scanning /proc/mounts for USB-backed filesystems under /tmp/mnt
ssd_trim: Skipping drive=/dev/sda (disabled via nvram: ssd_trim_24a9_205a_24092311730058_discard_max_bytes=0) for label=patriot mount=/tmp/mnt/patriot part=/dev/sda1 fs=ext4 vendor_id=24a9 vendor_name=ASolid
ssd_trim: Detected SSD candidate: label=st5 mount=/tmp/mnt/st5 part=/dev/sdb1 fs=ext4 vendor_id=04e8 vendor_name=Samsung
ssd_trim: Set 'unmap' (was 'full') -> /sys/block/sdb/device/scsi_disk/1:0:0:0/provisioning_mode
ssd_trim: Running fstrim on /tmp/mnt/st5...
ssd_trim: fstrim succeeded: /tmp/mnt/st5: 1821722705920 bytes trimmed
ssd_trim: Successfully trimmed all selected SSD mountpoints
discard_max_bytes value and remember it for subsequent runs.Thanks for the reply, but you were probably looking at an older commit - I removed that message when I introduced the IPv6-related changes.Just a wee pickup for now though, you noted on the main GitHub page, the comment below about only IPv4, however with the announcement above and a number of scripts available now referring to IPv6
Thanks for the update! Just tried out the new ssd_trim.sh script... sadly, it failed to see my Samsung SSD which is running inside a JMicron drive enclosure:2025-12-01 Update
This release brings a major overhaul of the SSD TRIM script and removes the Traffic Monitor table patch:
1. SSD TRIM logic has been completely reworked and includes the following improvements:
Sample run:
- The
pre-mounthook andssd_unmap.share no longer needed - all provisioning mode and UNMAP logic is now built into the main script. It's also no longer necessary to pass the disk label as an argument.- The script now automatically scans all attached USB storage devices, so there's no need to manually check and set vendor IDs.
- It detects suitable SSD devices, skipping HDDs and flash drives whenever their type can be determined.
- You can exclude specific partitions by label using
EXCLUDED_SSD_LABELSinconfig.sh.- When TRIM fails, the script now uses an adaptive fallback strategy that automatically tests a safe
discard_max_bytesvalue, saves it to nvram if successful, and permanently marks the device as unsupported (in nvram) if it cannot be made to work reliably.- All eligible SSDs are trimmed automatically in a single run.
Code:kuchkovsky@rt:/tmp/home/root# /jffs/scripts/ssd/ssd_trim.sh ssd_trim: Scanning /proc/mounts for USB-backed filesystems under /tmp/mnt ssd_trim: Skipping drive=/dev/sda (marked non-SSD) for label=patr mount=/tmp/mnt/patr part=/dev/sda1 fs=ext4 vendor_id=13fe ssd_trim: Detected SSD candidate: label=st5 mount=/tmp/mnt/st5 part=/dev/sdb1 fs=ext4 vendor_id=04e8 vendor_name=Samsung ssd_trim: Set 'unmap' (was 'full') -> /sys/block/sdb/device/scsi_disk/1:0:0:0/provisioning_mode ssd_trim: Running fstrim on /tmp/mnt/st5... ssd_trim: fstrim succeeded: /tmp/mnt/st5: 1821722705920 bytes trimmed ssd_trim: Successfully trimmed all selected SSD mountpoints
2. The Traffic Monitor table patch has been removed. It's no longer needed with the latest Merlin firmware - units are now displayed as Kbps/Mbps by default.
@XIII could you please try the updated version of the SSD TRIM script with your drive? It should now automatically tune thediscard_max_bytesvalue and remember it for subsequent runs.
ViktorJp@GT-AX6000-3C88:/jffs/scripts/ssd# sh ssd_trim.sh
ssd_trim: Skipping drive=/dev/sda (marked non-SSD) for label=ASUS-SSD mount=/tmp/mnt/ASUS-SSD part=/dev/sda1 fs=ext4 vendor_id=152d vendor_name=JMicron
ssd_trim: No suitable USB-backed mountpoints detected under /tmp/mnt; nothing to trim. Supported filesystems: ext2, ext3, ext4
ViktorJp@GT-AX6000-3C88:/jffs/scripts/ssd# sh ssd_trim.sh ASUS-SSD
ssd_trim: Scanning /proc/mounts for USB-backed filesystems under /tmp/mnt (label filter: ASUS-SSD)
ssd_trim: No suitable USB-backed mountpoints found for label=ASUS-SSD; nothing to trim. Supported filesystems: ext2, ext3, ext4
We use essential cookies to make this site work, and optional cookies to enhance your experience.
