Tutorial [Scripts][2025-12-07] SSD TRIM, IPSet-based Firewall & Tunnel Director, IPv6 Enhancements, WG Port Forwarder, and more
Hello. I copied the repo to my jffs folder and then made the files executable. But when I run sls
I get:
: not foundscripts/sdn/sdn_v6_shared.sh: line 2:
: not foundscripts/sdn/sdn_v6_shared.sh: line 10:
-sh: /jffs/scripts/sdn/sdn_v6_shared.sh: line 48: syntax error: unexpected word (expecting "do")
May I know where I am going wrong? Thanks.
I am only interested in IPv6 SLAAC and RA support for SDN networks currently. Thanks
Trying on Asus GT-AX6000 on 3006.102.6
I get:
It looks like a similar issue to the one @Milan encountered in this thread. Are you using a Windows tool like WinSCP to upload the files? It can mess up line endings. If so, could you change the transfer mode to binary (or a similar option) and reupload the files?
Generally, you only need the files explicitly listed in the SDN section: everything in /jffs/scripts/sdn, dhcpc-event + dnsmasq-sdn.postconf + firewall-start in /jffs/scripts, and profile.add in /jffs/configs. Everything else is not needed.
I used the scp which comes with windows now, I think its a part of OpenSSH. I will try to upload from a wsl distro and see if that is any better. Thanks.
Maybe when I’m brave enough to tinker with a non-critical router not affected by WAF…
So, I plucked up the courage to try this and wrote down my simplified steps for other folks wanting just SSD Trim but daunted by the process. Assumes you have SSH access to your Router (I use Putty) and can make Dirs and Transfer files (I use WinSCP).
Simplified how to (assuming using WinSCP for file transfers / creating directories) setup SSD Trim ONLY:
  • Create new directory “ssd” on router under /jffs/scripts/ i.e. /jffs/scripts/ssd.
  • Create new directory “utils” on router under /jffs/scripts/ i.e. /jffs/scripts/utils.
  • If asked by WinSCP, give these dirs 0644 permissions, which I believe is the default anyway.
  • Download the (currently) two files config.sh and ssd_trim.sh from the link on kuchovsky GitHub (see links below) to your desktop. Note: to download them without each being turned into html, do NOT right click save as, but rather click the file, then select download "raw" file.
  • Absolutely not necessary, but if you want to be neat, put them both in a local dir /jffs/scripts/ssd.
  • Similarly, download the common.sh file to your desktop. Again. not necessary, but if you want to be neat, put it in a local dir /jffs/scripts/utils.
  • WinSCP these three "raw" files from your desktop to the respective newly created dirs on the router i.e. config.sh and ssd_trim.sh -> /jffs/scripts/ssd and common.sh -> /jffs/scripts/utils.
  • That's it for the manual "install".
Running:
  • To run once manually, ssh into your router, go to /jffs/scripts/ssd
    cd /jffs/scripts/ssd
    and then run
    sh ssd_trim.sh
  • All going well (which it did on my two network systems) it should find your SSD and do the trim. It did not take long.
  • If you intend to run it manually often, consider adding this line to your profile.add file in /jffs/configs/. Then you can run it from root (or anywhere) with just 'ssd_trim'.
    alias ssd_trim="sh /jffs/scripts/ssd/ssd_trim.sh" # Run kuchkovsky's SSD Trim Utility
  • To restart profile.add, so you can run ssd_trim without a reboot, issue this in your terminal window:
    source /jffs/configs/profile.add
  • Separately, to set up a cron (scheduled) job for this, append these lines to your existing services-start file in /jffs/scripts/
# --------------------- Trim SSD Cron Job - ref Kuchovsky ------------------
# trim_ssd - run every Sunday 04:00, sends fstrim to USB SSDs
cru a trim_ssd "0 4 * * 0 /jffs/scripts/ssd/ssd_trim.sh"
Refs: Links to files on GitHub
https://github.com/kuchkovsky/asuswrt-merlin-scripts/tree/main/jffs/scripts/ssd
https://github.com/kuchkovsky/asuswrt-merlin-scripts/blob/main/jffs/scripts/ssd/config.sh
https://github.com/kuchkovsky/asuswrt-merlin-scripts/blob/main/jffs/scripts/utils/common.sh
Many thanks to @kuchkovsky, this is simply fantastic!
So the utils folder was also required. But I genuinely want to thank you for this script. I had enabled IPv6 via GUI and did not realise that was the reason IPv6 was broken on my android phone which I needed to bypass CG-NAT for Tailscale. You have genuinely made my life better and I want to thank you for it. And I hope the SLAAC part becomes a part of the firmware because I don't know who thought breaking SLAAC was a good way of distributing IPv6 subnets.
The deeper I look into this kind of setup and functionality, it seems to me that SDN is the line one crosses from SOHO networking into larger, more involved, potentially more “professional” config, and maybe asus hardware isn’t the best choice anymore. I’m certain other manufacturers have the same functionality out of the box (I’m thinking mikrotik’s RouterOS off the top of my head), but don’t let this musing deter anybody from continuing down this road.
Post in thread 'MerVLAN v0.50 Simple and Powerful VLAN Management **BETA**'
https://www.snbforums.com/threads/m...werful-vlan-management-beta.95936/post-977834
My opinion is there is a collab or partnership that might benefit everyone if it comes to pass.
I had tried running ssd_trim.sh against my Samsung T5 500GB USB SSD. It had not worked because changing provisioning_mode from full to unmap would fail. However, I kept my updater script and ran it today.
Well, something did change yesterday and the trim from the new version of ssd_trim.sh ran successfully. Thank you @kuchkovsky.
/jffs/scripts/ssd# ./ssd_trim.sh
ssd_trim: Scanning /proc/mounts for USB-backed filesystems under /tmp/mnt
ssd_trim: Detected SSD candidate: label=ent mount=/tmp/mnt/ent part=/dev/sda1 fs=ext4 vendor_id=04e8 vendor_name='Samsung'
ssd_trim: Set 'unmap' (was 'full') -> /sys/block/sda/device/scsi_disk/0:0:0:0/provisioning_mode
ssd_trim: Running fstrim on /tmp/mnt/ent...
ssd_trim: fstrim succeeded: /tmp/mnt/ent: 4914870272 bytes trimmed
ssd_trim: Detected SSD candidate: label=smb mount=/tmp/mnt/smb part=/dev/sda2 fs=ext4 vendor_id=04e8 vendor_name='Samsung'
ssd_trim: Running fstrim on /tmp/mnt/smb...
ssd_trim: fstrim succeeded: /tmp/mnt/smb: 7671943168 bytes trimmed
ssd_trim: Successfully trimmed all selected SSD mountpoints
2025-12-07​
This minor update introduces several improvements to the SSD TRIM script (thanks to @guynich on GitHub for reporting the issue and supplying detailed information):
  • Added -n to all echo writes to sysfs device files to ensure compatibility with 3004.388.x firmware.
  • Added a hardcoded fallback discard_max_bytes=33553920 (~32 MiB) when write_same_max_bytes is missing, invalid, or zero.
  • Added explicit handling for fstrim: FITRIM: Input/output error - if this error occurs and no working fallback value is found, the disk is permanently disabled via nvram for future runs.
  • Shortened the nvram key format used for storing discard_max_bytes.
  • Applied several cosmetic code-style cleanups.
Yes. Sorry, I forgot to mention that here. It's a default dependency for all scripts in the repo (it's noted in the README, though).
I recently merged the updated version mentioned in the post above, but waited to announce it until I received user confirmation that the fix worked. This update includes a fix for the 3004.388.x firmware, which is likely why it worked for you.
@kuchkovsky and @jksmurf thank you so much for this! I had tried and failed to get this working manually a few times in the past but using @jksmurf's post #64 above it worked!
ssd_trim: Running fstrim on /tmp/mnt/asususb...
ssd_trim: fstrim succeeded: /tmp/mnt/asususb: 175.8 GiB (188761800704 bytes) trimmed
ssd_trim: No SSD mountpoints required trimming
I noticed that I get that one last line every time saying "No SSD mountpoints required trimming". Is that confirmation trimming is complete and should I be getting that line as I don't see it on the others results above?
Failed for me:
Bash:
ssd_trim: Detected SSD candidate: label=data mount=/tmp/mnt/data part=/dev/sda1 fs=ext4 vendor_id=125f vendor_name='ADATA'
ssd_trim: Running fstrim on /tmp/mnt/data...
ssd_trim: ERROR: fstrim failed on /tmp/mnt/data: Input/output error
./ssd_trim.sh: line 485: can't create /sys/block/sda/queue/discard_max_bytes: Permission denied
ssd_trim: WARNING: Could not apply fallback discard_max_bytes=33553920 for /dev/sda
ssd_trim: WARNING: Disabling TRIM for /dev/sda (label=data mount=/tmp/mnt/data part=/dev/sda1 fs=ext4 vendor_id=125f vendor_name='ADATA') after I/O error; nvram ssd_trim_125f_a73a_403237D930E5_dmb=0
Note: ADATA is vendor of USB SSD enclosure, not SSD itself.
Nevermind me.. just not any USB enclosure does proper SATA implementation, it just can't do TRIM and that's all
I just ran it again this morning and I did not get that last line this time for some reason even without making any changes. All is well, not that it was an issue the first time.
ssd_trim: Detected SSD candidate: label=asususb mount=/tmp/mnt/asususb part=/dev/sda1 fs=ext4 vendor_id=6655 vendor_name='Best Buy'
ssd_trim: fstrim succeeded: /tmp/mnt/asususb: 483 MiB (506454016 bytes) trimmed
Just wanted to share a quick tidbit of what I do with this SSD trim script (along with a few other standalone scripts that run on a regular basis), and want to have more visibility into some logs to keep an eye on any potential issues...
1. Create a new runssdtrim.sh under your /jffs/scripts (make sure you chmod 755 runssdtrim.sh):
#!/bin/sh
if [ ! -f "/jffs/scripts/runssdtrim.log" ]; then touch /jffs/scripts/runssdtrim.log; fi
exec sh ssd_trim.sh 2>&1 | awk '{ print strftime("%b %d %Y %H:%M:%S --"), $0 }' >> /jffs/scripts/runssdtrim.log
exit 0
2. Make sure you create a cron job so it runs automatically each day (and make sure you add this same statement to your services-start file so it gets recreated on your next reboot):
cru a RunSSDTrim "30 4 * * * sh /jffs/scripts/runssdtrim.sh"
3. You should now have a running runssdtrim.log file under your /jffs/scripts that includes precise date/times so you can look at behavior over time.
Trim the log manually if you feel it's getting too big, or just delete it. It'll recreate itself the next time it runs. Enjoy!
#!/bin/sh
exit 0
Thanks for this.
Great idea to apply to track 'all' the things that are running in cron.
A slight spin on your spin ... I tend to minimise the writing to /jffs by sending all logs etc to the storage mounted on /mnt.
i.e. /tmp/mnt/RT-AX86UPro/Logs
(BTW: I have had a 'flaky' jffs on an old router ... it still works but get the occasional error !!!???)
Thanks for this.
That works too... I'm just lazy, and want to see everything in one place. Plus, it's very minimal logging so there's not really much concern for growth unless you just totally forget about it for about 8 years. :)
... in which time, router will be replaced/upgraded at least once.
#!/bin/sh
exit 0
Awesome, thanks for the tip!
I'm getting an Remote I/O error on my node. I followed the steps in the @jksmurf post #64 with the exception of WinSCP. I simply used wget to grab the files directly from @kuchkovsky GitHub page.
Everything worked flawlessly on the router, but I get the following error on the node:
ssd_trim: Detected SSD candidate: label=Ugreen-02 mount=/tmp/mnt/Ugreen-02 part=/dev/sda1 fs=ext4 vendor_id=0bda vendor_name='Ugreen'
ssd_trim: Set 'unmap' (was 'disabled') -> /sys/block/sda/device/scsi_disk/1:0:0:0/provisioning_mode
ssd_trim: Running fstrim on /tmp/mnt/Ugreen-02...
ssd_trim: ERROR: fstrim failed on /tmp/mnt/Ugreen-02: Remote I/O error
ssd_trim: Retrying fstrim on /tmp/mnt/Ugreen-02 with discard_max_bytes=33553920 (fallback from write_same_max_bytes)...
ssd_trim: ERROR: fstrim still failed on /tmp/mnt/Ugreen-02 with fallback discard_max_bytes=33553920: Operation not supported
ssd_trim: WARNING: Disabling TRIM for /dev/sda (label=Ugreen-02 mount=/tmp/mnt/Ugreen-02 part=/dev/sda1 fs=ext4 vendor_id=0bda vendor_name='Ugreen') after I/O error; nvram ssd_trim_0bda_9201_133309274CE5_dmb=0
Any ideas on how to correct this? Both USB connected SSD drives and enclosures are identical with same model routers (see signature).
TIA
TIA
It looks like the issue is with either the enclosure or the SSD, since the script tries multiple approaches and none of them work. But you mentioned the hardware is identical in both cases 🤔
Have you tried swapping the SSD and enclosure between the routers, just as a test? There could be some internal hardware difference in the enclosure. Chinese devices sometimes use random internal components even within the same model.
Wouldn't that mean reformatting and setting up AMTM and associated add-ons from scratch? Or can I simply safely remove the enclosure from the router and plug it into the node?
