scuse me Merlin, question about debricking?
GoNz0
I did a stupid today, I hit the insert key by accident and screwed up my cfe file, then to top it off I flashed it on my N66u.
It won't go into recovery, just 3 lights stuck on so I know it will need opening up to revive it.
Can you advise on the best method and what cables are needed please?
You may not be able to.
I bought a bricked rt-n66u. Had 3 solid LEDs on. I hooked up a serial cable and got no output in putty.
You screwed up the bootloader. Probably jtag time.
The only way is using a JTAG cable, JTAG software, and soldering headers on your router's pcboard.
Serial or firmware recovery won't help you if the bootloader is toast.
Cheers, getting a New router anyway, this will be a project to repair :)
Sent from my GT-I9505 using Tapatalk
Could someone link me to a suitable jtag board on eBay ?
Lots of choices so I don't want to throw money away :(
