Serious problems with spdMerlin
Prokktor
I installed spdMerlin und every half an hour my internet stops working for 2 minutes, thats probably when the speed test runs.
So I want to get rid of spdMerlin but how?
It is in the list of processes so it runs, but there is no web ui anymore (since the last merlin update).
I connected through ssh lauched amtm and updated everything there was.
When I launch spdMerlin from here it simply says:
"Upgrading Database..."
And even hours later no menu appears...
So I am stuck... how to get rid of spdMerlin?
Regards and Thanks
Martin
which model router?
sounds like you probably might need to do a factory -or possibly even nuclear- reset.
If you want to uninstall spdmerlin perhaps can try
/jffs/scripts/spdmerlin uninstall
all Jack's scripts expose an uninstall command directly
