Server not found
Ramz
Hello my wife is working from home now. When she tries to connect to work she cant keeps getting server not found. Using Asus u86 with Merlin and DNS google 1.1.1.1 8.8.8.8. Funny thing is when I connect via ethernet, I can get to her work server but Via Wifi I cant. I checked the error and get "possible DNS-rebind attack detected" any ideas?? I dont want to run a wire to her computer if possible as she wants to work from anywhere in the house.
Turn off "Enable DNS Rebind protection" on the WAN page, then test again. If it works, you can look to "allow" the blocked domain via a custom config file, but it may be easier to just leave DNS rebind disabled for now.
Ok what else to I need to disable if that dose not work? That did not work just tried.
Is she connecting to a "normal" WiFi network or a "guest" WiFi network on your router? Is she using a VPN client or is her work server accessible over the public internet? Do the rebind messages you saw include the domain name of her employer's server?
Normal wifi and no VPN yes it does include her employers server.
... as she wants to work from anywhere in the house.
So it sounds like this is a laptop? If so temporarily move the laptop near enough to the router so that you can connect to it by cable instead of WiFi (remember to disable the WiFi). Then try again. If the problem persists you know that it's an issue with the laptop and nothing to do with WiFi.
Do you have any custom DNS servers defined in the DHCP page, or DNSFilter page? I'm not sure why the difference in WiFi versus Ethernet unless you're assigning different DNS servers per MAC address, and MAC addresses would be different between a WiFi adapter and an Ethernet adapter.
No point guessing though until she tests with Rebind protection disabled.
No I do not have custom DNS. just google DNS
Here are a few ideas from my experiences.
Lets see what your wife's PC is using for DNS when connected to your WIFI:
With your wife's PC connected to your WIFI do the following:
press WIN + R
type cmd in the run box
type ipconfig /all in the dos window
tell us what it says in the Wireless LAN adapter values under DNS Servers
Then type nslookup wifes.workaddress.com 1.1.1.1
You should see something like:
C:\Users\blabla>nslookup hello.com 1.1.1.1
Server:  one.one.one.one
Address:  1.1.1.1
Non-authoritative answer:
Addresses:  2001:4860:4802:38::15
          2001:4860:4802:34::15
          2001:4860:4802:32::15
          2001:4860:4802:36::15
          216.239.38.21
          216.239.34.21
          216.239.36.21
          216.239.32.21
Then run the same thing without the 1.1.1.1
Hopefully you will see the same results:
Server:  router.blessthishouse.home
Address:  192.168.1.1
Addresses:  2001:4860:4802:36::15
          216.239.32.21
          216.239.36.21
          216.239.34.21
          216.239.38.21
nslookup domain.to.find dns.dserver.to.use
The first test was bypassing your DNS config and asking the specified DNS server directly for the address
The second test asked your PC to use its defined DNS servers from the DNS Servers listed under ipconfig /all
Let us know what you get...
press WIN + R
Address:  1.1.1.1
          216.239.38.21
          216.239.34.21
          216.239.36.21
          216.239.32.21
          216.239.32.21
          216.239.36.21
          216.239.34.21
          216.239.38.21
I got 192.168.50.1 both times on DNS server.
ok in a command prompt type: nslookup the.domain-in-question.com 1.1.1.1
and copy and paste the results below:
it should look like:
Address:  1.1.1.1
         216.239.38.21
         216.239.34.21
         216.239.36.21
         216.239.32.21
we are interested in the lower response
Then run the next: nslookup the.domain-in-question.com
and paste it
         216.239.38.21
         216.239.34.21
         216.239.36.21
         216.239.32.21
if you specify the 1.1.1.1 in the first example the top should not say 192.168.50.1
Address:  1.1.1.1
         216.239.38.21
         216.239.34.21
         216.239.36.21
         216.239.32.21
and paste it
         216.239.38.21
         216.239.34.21
         216.239.36.21
         216.239.32.21
I got this time 127.0.0.1 if that helps.
Just post the complete output of the commands as requested. Cryptic one line replies without any of the surrounding information is not helpful.
Ok will do once i am back home
C:\Users\Teen>nslookup starmetrolandmedia.my.salesforce.com 9.9.9.9
I did two this is what I get one with Quad9 then chenged to cloudfare
Server: dns9.quad9.net
Address: 9.9.9.9
*** dns9.quad9.net can't find starmetrolandmedia.my.salesforce.com: Server failed
Address: 9.9.9.9
C:\Users\Teen>nslookup starmetrolandmedia.my.salesforce.com 1.1.1.1
Address: 1.1.1.1
*** one.one.one.one can't find starmetrolandmedia.my.salesforce.com: Server
Who's PC is this, yours or your wife's?
On the same PC post the output of this command:
ipconfig /all
What level of Merlin? If you have DoT enabled (DNS Privacy) try disabling it.
ipconfig /all
Hi its mine as I cant get to her web site either so both laptops have the same server not found
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 1030
Physical Address. . . . . . . . . : BC-77-37-76-F4-8F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::c0c1:335a:4d76:e2d4%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.50.248(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, March 28, 2020 5:58:15 PM
Lease Expires . . . . . . . . . . : Sunday, March 29, 2020 6:13:46 PM
Default Gateway . . . . . . . . . : 192.168.50.1
DHCP Server . . . . . . . . . . . : 192.168.50.1
DHCPv6 IAID . . . . . . . . . . . : 264009527
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-15-71-71-38-18-03-73-54-07-A3
DNS Servers . . . . . . . . . . . : 192.168.50.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : BC-77-37-76-F4-93
