services-start failing to start
txcanuck
I have a quite old /jffs/scripts/services-start script - it has worked for a long time, but only on 386.2 and later seems to not start on boot. Could it be related to this also perhaps (trying to check the log I write to in that script),
# logread
logread: can't find syslogd buffer: No such file or directory
Thanks!
Sorry! Wasn't sure if it was a generic issue - it only seemed to happen on the 386.2 upgrade.
Went in, fully wiped jffs2, put the file back => seems to run now. Something / somehow it appears that jffs2 was corrupted on install. And BTW, it's an RT-AC68U.
Thanks!
Have you tried to do a factory reset then try again? What about other scripts, such as wan-event?
Did you try `chmod +x /jffs/scripts/services-start`
