Setting Wireless VLAN? on RT-AC3200
RandyVanF
I am wondering if anyone knows how to set the VLAN of the Wireless network to a VLAN different from default internal VLAN. I have a requirement to put the Wireless network on a different network than that of the default NAT routed internal LAN network. The WAN side is still connected to the internet and the internal NAT routed network would be like VLAN 10 and the Wireless network would be VLAN 20 on the internal network.
Here is a robocfg show result.
myuser:/tmp/home/root# robocfg show
Switch: enabled
Port 0: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:25:03:b7:f1:00
Port 2: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 3: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 4: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
Port 8: DOWN enabled stp: none vlan: 1 jumbo: off mac: 00:00:00:00:00:00
VLANs: BCM5301x enabled mac_check mac_hash
1: vlan1: 0 1 2 3 4 5t
2: vlan2: 5t
1045: vlan1045: 0t 5 7t 8t
1046: vlan1046: 4t 5 7
1047: vlan1047: 0 1 4t 8u
1099: vlan1099: 1 3 4 7 8t
1100: vlan1100: 0t 1t 2t
1101: vlan1101: 0t 1t 3t 5t 7 8u
1102: vlan1102: 3t 5t 7t 8t
1103: vlan1103: 3t 4t 5t 7t
Randy
The previous robocfg show was for AP mode. Here is the router mode result.
Switch: enabled
Port 0: DOWN enabled stp: none vlan: 2 jumbo: off mac: 00:00:00:00:00:00
Port 1: 1000FD enabled stp: none vlan: 1 jumbo: off mac: 00:50:56:83:5e:e7
Port 2: 1000FD enabled stp: none vlan: 1 jumbo: off mac: ec:f4:bb:34:b6:1e
Port 8: DOWN enabled stp: none vlan: 2 jumbo: off mac: 00:00:00:00:00:00
1: vlan1: 1 2 3 4 5t
2: vlan2: 0 5
