Setup AP on RP-AC68U; 2.5ghz network dont show
I changed from the WAN port, to LAN and it works with repeater mode.
In repeater mode there shouldn't be any cables at all between the Asus and the Telia. The only time you should connect them together with a cable is when the Asus is configured as an access point.
Yes thats the thing. I had it setup in repeater mode some months ago, with the cable attached, so i could extend with another cable to another computer in the house without wifi. That worked fine.
I will try setting up AP again, later today. Will report how it goes.
Connecting a PC to the Asus via Ethernet in repeater mode will probably be OK, although it's not a documented setup. What you shouldn't do is connect a cable between the Asus and the Telia when it's in repeater mode. Doing so might create a network loop with unpredictable results.
