Shellshock BASH bug and RT-N66U
Jelf
The RT-N66U is driven by linux.
The BASH shell is often used with linux installations.
The BASH shell can be hacked via the shellshock bug that hit the news yesterday.
So.......where does that leave the Merlin world?
Can our home routers be hacked?
Is there anything we can do?
Is there anything that Merlin can do?
Is it time to go live in a cave?
Bash is not used on ASUS routers, only good old sh shell. If you do "which bash" (no quotes) you'll see it returns nothing while "which sh" returns /bin/sh
The Asuswrt shell is called "ash", and is provided by Busybox.
The sh symlink is merely for convenience/compatibility, and probably carries no direct code relation to neither bash nor sh.
I was wrong then. I didn't follow links and just did which sh which gave me the impression sh is used
I ran the test command and it passed as not vulnerable (if you run this command and it prints vulnerable, you are exposed).
env x='() { :;}; echo vulnerable' sh -c "echo this is a test"
"ShellShock" bash bug?
Does the Merlin FW vulnerable?
Based on Asus firmware and considering that this is very new... I would say yes, it is.
One more reason why I continue to think so highly of Asus routers. :D
Actually, the vast majority of routers also use Busybox, because it's very lightweight.
Threads merged
I've merged all the threads into this one. Please continue the discussion here.
N66U with standard firmware apparently not affected
Good discussion here: http://www.troyhunt.com/2014/09/everything-you-need-to-know-about.html?m=1
Clip from the article:
"discovering if you’re at risk is trivial as it’s such an easily reproducible risk. There’s a very simple test The Register suggests which is just running this command within your shell:
env X="() { :;} ; echo busted" /bin/sh -c "echo stuff"
You get “busted” echo’d back out and you’ve successfully exploited the bug."
Article referenced: http://www.theregister.co.uk/2014/09/24/bash_shell_vuln/
I enabled telnet on my N66U, logged in, and issued the command - I got "stuff" echoed back so apparently the N66U is not vulnerable running stock firmware. And, as noted earlier it's not running bash (or sh) anyway.
Someone with Merlin could do the same - but I think it's running the same busybox shell (ash) so there shouldn't be any difference
so in layman's terms, those of us on the N66U with the latest Merlin fw (376.47) are safe?
No version of Asuswrt or Asuswrt-merlin is vulnerable. We do not use bash.
Sent from my Nexus 4 using Tapatalk
I've installed optware then bash on my ac68
when I substitute /opt/bin/bash into the proper place in the test command two lines are returned,
busted
stuff
or
vulnerable
this is a test
So, I guess I've got a problem?
Safe
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Sat Sep 20 18:50:48 UTC 2014
admin@RT-AC68U:/tmp/home/root# env x='() { :;}; echo Vulnerable' bash -c "echo T
his is a test"
env: can't execute 'bash': No such file or directory
admin@RT-AC68U:/tmp/home/root# env x='() { :;}; echo Vulnerable' sh -c "echo Thi
s is a test"
This is a test
Just done the same test on my "out-of-the-box" RT-AC56U ....
admin@RT-AC56U:/tmp/home/root# env X="() { :;} ; echo busted" /bin/sh -c "echo stuff"
stuff
So it looks as if the standard Asus offering is OK ....
busted
stuff
or
vulnerable
this is a test
Yes you do ....
