Simple test request on R7800
Odkrys
Hi.
Can someone please run the following test on R7800 5Ghz?
It would be nice if it was a Windows laptop.
2 cmds, one for ping and another for iperf.
iperf -s on R7800.
ping 192.168.x.1 -t
iperf -c 192.168.x.1 (router) -w 1M -P 5
and then,
iperf -c 192.168.x.1 (router) -w 64k -P 5
I am curious about the throughput and latency of the qualcomm wireless chipset.
HELLO_wORLD
iPerf 3 from a Samsung phone, Wifi 5GHz @ 433 Mbps.
Command from phone: iperf3 -c 192.158.0.1 -P 5
Server listening on 5201
Accepted connection from 192.168.0.3, port 37708
[  5] local 192.168.0.1 port 5201 connected to 192.168.0.3 port 37710
[  8] local 192.168.0.1 port 5201 connected to 192.168.0.3 port 37712
[ 10] local 192.168.0.1 port 5201 connected to 192.168.0.3 port 37714
[ 12] local 192.168.0.1 port 5201 connected to 192.168.0.3 port 37716
[ 14] local 192.168.0.1 port 5201 connected to 192.168.0.3 port 37718
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-10.26  sec  54.9 MBytes  44.9 Mbits/sec
[  8]   0.00-10.26  sec  55.2 MBytes  45.1 Mbits/sec
[ 10]   0.00-10.26  sec  54.1 MBytes  44.2 Mbits/sec
[ 12]   0.00-10.26  sec  57.1 MBytes  46.7 Mbits/sec
[ 14]   0.00-10.26  sec  54.4 MBytes  44.5 Mbits/sec
[SUM]   0.00-10.26  sec   276 MBytes   225 Mbits/sec
[  5]   0.00-10.26  sec  54.9 MBytes  44.9 Mbits/sec                  receiver
[  8]   0.00-10.26  sec  55.2 MBytes  45.1 Mbits/sec                  receiver
[ 10]   0.00-10.26  sec  54.1 MBytes  44.2 Mbits/sec                  receiver
[ 12]   0.00-10.26  sec  57.1 MBytes  46.7 Mbits/sec                  receiver
[ 14]   0.00-10.26  sec  54.4 MBytes  44.5 Mbits/sec                  receiver
[SUM]   0.00-10.26  sec   276 MBytes   225 Mbits/sec                  receiver
Odkrys
Thanks. But i need the result of ping test.
I am seeing a significant increase in latency in tcp concurrent situation on asus rt-ac86u.
This is not a problem for small windows sizes, but seems to be a significant problem for typical window sizes.
In a fast bandwidth (my 500mbps internet, this is close to the throughput limit of 5Ghz 866mbps), it looks pretty bad when I need simultaneous tcp connection.
iperf -c 192.168.50.1 -w 1M -P 5
Reply from 192.168.50.1: bytes=32 time=1ms TTL=64
Reply from 192.168.50.1: bytes=32 time=41ms TTL=64
Reply from 192.168.50.1: bytes=32 time=81ms TTL=64
Reply from 192.168.50.1: bytes=32 time=79ms TTL=64
Reply from 192.168.50.1: bytes=32 time=82ms TTL=64
Reply from 192.168.50.1: bytes=32 time=73ms TTL=64
Reply from 192.168.50.1: bytes=32 time=77ms TTL=64
Reply from 192.168.50.1: bytes=32 time=78ms TTL=64
Reply from 192.168.50.1: bytes=32 time=72ms TTL=64
iperf -c 192.168.50.1 -w 64k -P 5
Reply from 192.168.50.1: bytes=32 time=2ms TTL=64
Reply from 192.168.50.1: bytes=32 time=6ms TTL=64
Reply from 192.168.50.1: bytes=32 time=17ms TTL=64
Reply from 192.168.50.1: bytes=32 time=10ms TTL=64
Reply from 192.168.50.1: bytes=32 time=7ms TTL=64
Reply from 192.168.50.1: bytes=32 time=11ms TTL=64
Reply from 192.168.50.1: bytes=32 time=5ms TTL=64
HELLO_wORLD
I don’t think I can make an accurate test for you.
Here are my pings to iPad, then phone, both on 5GHz, but without iPerf running :
[email protected]:~$ ping 192.168.0.6
PING 192.168.0.6 (192.168.0.6): 56 data bytes
64 bytes from 192.168.0.6: seq=0 ttl=64 time=2.249 ms
64 bytes from 192.168.0.6: seq=1 ttl=64 time=3.187 ms
64 bytes from 192.168.0.6: seq=2 ttl=64 time=105.592 ms
64 bytes from 192.168.0.6: seq=3 ttl=64 time=3.343 ms
64 bytes from 192.168.0.6: seq=4 ttl=64 time=80.537 ms
64 bytes from 192.168.0.6: seq=5 ttl=64 time=103.843 ms
64 bytes from 192.168.0.6: seq=6 ttl=64 time=26.336 ms
64 bytes from 192.168.0.6: seq=7 ttl=64 time=49.422 ms
64 bytes from 192.168.0.6: seq=8 ttl=64 time=74.008 ms
64 bytes from 192.168.0.6: seq=9 ttl=64 time=96.939 ms
64 bytes from 192.168.0.6: seq=10 ttl=64 time=18.932 ms
64 bytes from 192.168.0.6: seq=11 ttl=64 time=43.174 ms
64 bytes from 192.168.0.6: seq=12 ttl=64 time=4.030 ms
64 bytes from 192.168.0.6: seq=13 ttl=64 time=21.712 ms
64 bytes from 192.168.0.6: seq=14 ttl=64 time=12.215 ms
64 bytes from 192.168.0.6: seq=15 ttl=64 time=35.333 ms
64 bytes from 192.168.0.6: seq=16 ttl=64 time=59.544 ms
^C
--- 192.168.0.6 ping statistics ---
17 packets transmitted, 17 packets received, 0% packet loss
round-trip min/avg/max = 2.249/43.552/105.592 ms
[email protected]:~$ ping 192.168.0.3
PING 192.168.0.3 (192.168.0.3): 56 data bytes
64 bytes from 192.168.0.3: seq=0 ttl=64 time=5.436 ms
64 bytes from 192.168.0.3: seq=1 ttl=64 time=5.311 ms
64 bytes from 192.168.0.3: seq=2 ttl=64 time=35.145 ms
64 bytes from 192.168.0.3: seq=3 ttl=64 time=58.701 ms
64 bytes from 192.168.0.3: seq=4 ttl=64 time=2.343 ms
64 bytes from 192.168.0.3: seq=5 ttl=64 time=107.810 ms
64 bytes from 192.168.0.3: seq=6 ttl=64 time=26.929 ms
64 bytes from 192.168.0.3: seq=7 ttl=64 time=52.952 ms
64 bytes from 192.168.0.3: seq=8 ttl=64 time=75.195 ms
64 bytes from 192.168.0.3: seq=9 ttl=64 time=102.031 ms
64 bytes from 192.168.0.3: seq=10 ttl=64 time=21.899 ms
64 bytes from 192.168.0.3: seq=11 ttl=64 time=45.173 ms
64 bytes from 192.168.0.3: seq=12 ttl=64 time=68.916 ms
^C
--- 192.168.0.3 ping statistics ---
13 packets transmitted, 13 packets received, 0% packet loss
round-trip min/avg/max = 2.343/46.757/107.810 ms
I guess tablets and phones are not good for these tests.
Voxel
Part of the Furniture
On Windows laptop:
iperf3.exe -s
on R7800 (AP mode):
[email protected]:~$ iperf3 -c 192.168.200.203 -P 5 -R
Connecting to host 192.168.200.203, port 5201
Reverse mode, remote host 192.168.200.203 is sending
[  5] local 192.168.200.3 port 40518 connected to 192.168.200.203 port 5201
[  7] local 192.168.200.3 port 40519 connected to 192.168.200.203 port 5201
[  9] local 192.168.200.3 port 40520 connected to 192.168.200.203 port 5201
[ 11] local 192.168.200.3 port 40521 connected to 192.168.200.203 port 5201
[ 13] local 192.168.200.3 port 40522 connected to 192.168.200.203 port 5201
[  5]   0.00-1.00   sec  16.4 MBytes   137 Mbits/sec
[  7]   0.00-1.00   sec  11.5 MBytes  96.7 Mbits/sec
[  9]   0.00-1.00   sec  9.69 MBytes  81.3 Mbits/sec
[ 11]   0.00-1.00   sec  10.0 MBytes  83.9 Mbits/sec
[ 13]   0.00-1.00   sec  9.63 MBytes  80.7 Mbits/sec
[SUM]   0.00-1.00   sec  57.2 MBytes   480 Mbits/sec
[  5]   1.00-2.00   sec  17.0 MBytes   143 Mbits/sec
[  7]   1.00-2.00   sec  13.7 MBytes   115 Mbits/sec
[  9]   1.00-2.00   sec  9.31 MBytes  78.1 Mbits/sec
[ 11]   1.00-2.00   sec  9.25 MBytes  77.6 Mbits/sec
[ 13]   1.00-2.00   sec  9.34 MBytes  78.4 Mbits/sec
[SUM]   1.00-2.00   sec  58.6 MBytes   491 Mbits/sec
[  5]   2.00-3.00   sec  15.1 MBytes   127 Mbits/sec
[  7]   2.00-3.00   sec  12.7 MBytes   107 Mbits/sec
[  9]   2.00-3.00   sec  10.6 MBytes  88.6 Mbits/sec
[ 11]   2.00-3.00   sec  7.50 MBytes  62.9 Mbits/sec
[ 13]   2.00-3.00   sec  9.24 MBytes  77.5 Mbits/sec
[SUM]   2.00-3.00   sec  55.2 MBytes   463 Mbits/sec
[  5]   3.00-4.00   sec  12.8 MBytes   107 Mbits/sec
[  7]   3.00-4.00   sec  10.6 MBytes  88.5 Mbits/sec
[  9]   3.00-4.00   sec  10.9 MBytes  91.3 Mbits/sec
[ 11]   3.00-4.00   sec  9.53 MBytes  79.9 Mbits/sec
[ 13]   3.00-4.00   sec  10.1 MBytes  84.8 Mbits/sec
[SUM]   3.00-4.00   sec  53.8 MBytes   452 Mbits/sec
[  5]   4.00-5.00   sec  11.6 MBytes  97.6 Mbits/sec
[  7]   4.00-5.00   sec  9.65 MBytes  80.9 Mbits/sec
[  9]   4.00-5.00   sec  10.6 MBytes  88.9 Mbits/sec
[ 11]   4.00-5.00   sec  9.30 MBytes  78.0 Mbits/sec
[ 13]   4.00-5.00   sec  10.2 MBytes  85.6 Mbits/sec
[SUM]   4.00-5.00   sec  51.4 MBytes   431 Mbits/sec
[  5]   5.00-6.00   sec  11.9 MBytes  99.7 Mbits/sec
[  7]   5.00-6.00   sec  10.9 MBytes  91.8 Mbits/sec
[  9]   5.00-6.00   sec  11.7 MBytes  98.2 Mbits/sec
[ 11]   5.00-6.00   sec  10.1 MBytes  84.6 Mbits/sec
[ 13]   5.00-6.00   sec  11.3 MBytes  94.4 Mbits/sec
[SUM]   5.00-6.00   sec  55.9 MBytes   469 Mbits/sec
[  5]   6.00-7.00   sec  9.61 MBytes  80.6 Mbits/sec
[  7]   6.00-7.00   sec  10.4 MBytes  86.9 Mbits/sec
[  9]   6.00-7.00   sec  11.3 MBytes  94.6 Mbits/sec
[ 11]   6.00-7.00   sec  10.1 MBytes  84.8 Mbits/sec
[ 13]   6.00-7.00   sec  10.8 MBytes  90.9 Mbits/sec
[SUM]   6.00-7.00   sec  52.2 MBytes   438 Mbits/sec
[  5]   7.00-8.00   sec  9.69 MBytes  81.3 Mbits/sec
[  7]   7.00-8.00   sec  10.2 MBytes  85.5 Mbits/sec
[  9]   7.00-8.00   sec  11.3 MBytes  94.8 Mbits/sec
[ 11]   7.00-8.00   sec  11.4 MBytes  95.9 Mbits/sec
[ 13]   7.00-8.00   sec  10.9 MBytes  91.3 Mbits/sec
[SUM]   7.00-8.00   sec  53.5 MBytes   449 Mbits/sec
[  5]   8.00-9.00   sec  10.3 MBytes  86.4 Mbits/sec
[  7]   8.00-9.00   sec  9.80 MBytes  82.2 Mbits/sec
[  9]   8.00-9.00   sec  10.9 MBytes  91.4 Mbits/sec
[ 11]   8.00-9.00   sec  11.2 MBytes  93.7 Mbits/sec
[ 13]   8.00-9.00   sec  10.5 MBytes  87.7 Mbits/sec
[SUM]   8.00-9.00   sec  52.6 MBytes   441 Mbits/sec
[  5]   9.00-10.00  sec  10.6 MBytes  88.8 Mbits/sec
[  7]   9.00-10.00  sec  9.69 MBytes  81.3 Mbits/sec
[  9]   9.00-10.00  sec  10.5 MBytes  88.3 Mbits/sec
[ 11]   9.00-10.00  sec  10.6 MBytes  89.2 Mbits/sec
[ 13]   9.00-10.00  sec  10.3 MBytes  86.4 Mbits/sec
[SUM]   9.00-10.00  sec  51.7 MBytes   434 Mbits/sec
[  5]   0.00-10.03  sec   126 MBytes   105 Mbits/sec                  sender
[  5]   0.00-10.00  sec   125 MBytes   105 Mbits/sec                  receiver
[  7]   0.00-10.03  sec   110 MBytes  92.0 Mbits/sec                  sender
[  7]   0.00-10.00  sec   109 MBytes  91.5 Mbits/sec                  receiver
[  9]   0.00-10.03  sec   108 MBytes  90.1 Mbits/sec                  sender
[  9]   0.00-10.00  sec   107 MBytes  89.5 Mbits/sec                  receiver
[ 11]   0.00-10.03  sec   100 MBytes  83.6 Mbits/sec                  sender
[ 11]   0.00-10.00  sec  99.0 MBytes  83.0 Mbits/sec                  receiver
[ 13]   0.00-10.03  sec   103 MBytes  86.3 Mbits/sec                  sender
[ 13]   0.00-10.00  sec   102 MBytes  85.8 Mbits/sec                  receiver
[SUM]   0.00-10.03  sec   547 MBytes   457 Mbits/sec                  sender
[SUM]   0.00-10.00  sec   542 MBytes   455 Mbits/sec                  receiver
iperf Done.
Ping from Windows laptop to R7800 (iperf3 is running):
ping -n 20 192.168.200.2
Pinging 192.168.200.2 with 32 bytes of data:
Reply from 192.168.200.2: bytes=32 time=60ms TTL=64
Reply from 192.168.200.2: bytes=32 time=40ms TTL=64
Reply from 192.168.200.2: bytes=32 time=77ms TTL=64
Reply from 192.168.200.2: bytes=32 time=83ms TTL=64
Reply from 192.168.200.2: bytes=32 time=69ms TTL=64
Reply from 192.168.200.2: bytes=32 time=108ms TTL=64
Reply from 192.168.200.2: bytes=32 time=112ms TTL=64
Reply from 192.168.200.2: bytes=32 time=73ms TTL=64
Reply from 192.168.200.2: bytes=32 time=6ms TTL=64
Reply from 192.168.200.2: bytes=32 time=5ms TTL=64
Reply from 192.168.200.2: bytes=32 time=8ms TTL=64
Connection: 5GHz.
Voxel.
HELLO_wORLD Aegis Aegis (simple yet effective protection) NETGEAR AC Wireless 314
D R7800 bufferbloat test NETGEAR AC Wireless 10
