Skynet Skynet fails to start after install
GlaucomaPredator
I have an issue with Skynet after I install it the services fail.
║ Test Description                  ║ Result        ║
║ Internet-Connectivity             ║ [Passed]                                                              ║
║ Public IP Address                 ║ [Passed]                                                              ║
║ Write Permission                  ║ [Passed]                                                              ║
║ Config File                       ║ [Passed]                                                              ║
║ Firewall-Start Entry              ║ [Passed]                                                              ║
║ Services-Stop Entry               ║ [Passed]                                                              ║
║ Service-Event Entry               ║ [Passed]                                                              ║
║ Profile.add Entry                 ║ grep: /jffs/configs/profile.add: No such file or directory
[Failed]                                                              ║
║ SWAP File                         ║ [Passed]                                                              ║
║ Cron Jobs                         ║ [Failed]                                                              ║
║ NTP Sync                          ║ [Passed]                                                              ║
║ Log Level 7 Settings              ║ [Passed]                                                              ║
║ Duplicate Rules In RAW            ║ [Passed]                                                              ║
║ IPSets                            ║ [Failed]                                                              ║
║ IPTables Rules                    ║ [Failed]                                                              ║
║ Local WebUI Files                 ║ [Failed]                                                              ║
║ Mounted WebUI Files               ║ [Failed]                                                              ║
║ MenuTree.js Entry                 ║ [Failed]                                                              ║
║ 11/18 Tests Sucessful        ║
As you can see I have failing Tests
