Skynet Overkill List
Jack-Sparr0w
/usr/sbin/curl -s "https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/08d0c3e47a96d843dba8e33101b6644eb8205cee/firewall.sh" -o "/jffs/scripts/firewall" && chmod 755 /jffs/scripts/firewall && sh /jffs/scripts/firewall install
This is only version of Skynet that works with this list, use this command line after you type password and username. do not go into amtm just copy and paste code to use his version of Skynet. eliminate /CODE] at end and
 at start of command i should look like this /usr/sbin/curl -s "https://raw.githubusercontent.com/Adamm00/IPSet_ASUS/08d0c3e47a96d843dba8e33101b6644eb8205cee/firewall.sh" -o "/jffs/scripts/firewall" && chmod 755 /jffs/scripts/firewall && sh /jffs/scripts/firewall install
country blocklist if needed cu kp ir sy ru al ba bg hr mk xk me ro rs si by mm cf cd et hk iq lb lr ni sd ve ye af so ss zw ly bi ml cn ht md gt lk cy ci vn er br tr bd pk in np gh mx co lt na hn kh eg dz gn ne sl pl id my th am az ge kz kg tj uz tm lv kr sa ae ng bf td cg sv ke mr ph to cz ee hu il kw om qa sk va do ua sc it mn au no za fr ad pt mo cl ec pa py sr uy mu ma tz nz dk jp sg ar aq bb bo bs bw jm ug bh cr aw
and a good anti dos asn list to add to asn blocking
AS16276
AS200373
AS14061
AS4134
AS55386
AS7552
AS45899
AS132203
AS63949
AS51167
AS4766
AS9299
AS18403
AS135918
AS7713
AS142594
AS8452
AS399668
AS142594
AS7979
AS210743
AS200651
AS211590
AS136907
This is only version of Skynet that works with this list, use this command line after you type password and username. do not go into amtm just copy and paste code to use his version of Skynet and press enter
