Jack-Sparr0w
Just wanna avoid the oops I didn't know I just fixed it. or just noticed it was missing something. I have been here for long time now and just know how this story goes.
So I think you should also know by now there's always a risk using 3rd party scriptsJust wanna avoid the oops I didn't know I just fixed it. or just noticed it was missing something. I have been here for long time now and just know how this story goes.
Several changes were already made to accommodate lists like your psychotic list. Try it.does his new skynet only allow 15 addresses max, and takes way longer to add a list, or has that been fixed. when i added my list to that version it failed after the 15 mark, just a bunch of failed to loads.
firewall debug info extended command. One failure is reported;Log Level 4 Settings ║ [Failed]
EDIT: I found the issue.... I had to change the syslog error level from ERROR to WARNING. All tests are passing now. Will have to wait to see if I start getting any stats now.
I finally took the plunge and update Skynet to the most recent version of Ver8.
After a week, I have no stats. All charts say No data to display. I have tried to click on the generate stats button.
I ran thefirewall debug info extendedcommand. One failure is reported;
Code:Log Level 4 Settings ║ [Failed]
How do I go about fixing this error?
Default message log level
notice
Log only messages more urgent than
debug
getting message on router reboot only, and its on the top of each hour --> Jan 3 06:00:00 Skynet: [✘] Rule Integrity Violation - Restarting Firewall [ #21 ]
I have to login to amtm and restart skynet to make it go away. this has been happening ever since i upgraded to skynet 8.x.x
Something is wrong with your inbound logging rule, please post the output of;#21: Inbound LOG
sh /jffs/scripts/firewall debug info
Add settings toggle for Extended Stats (dnsmasq log matching for blocked IP's)
Improve debug watch - reduce chain commands to minimise CPU usage
Rename Extended_DNSStats() > Generate_Ban_Stats()
Set default log size as 10MB
Update readme
Refactor menu information
Huge efficiency improvement in logging cpu usage, seems I can force close terminal window with debug open and not see grep indefinitely spiking to 50%, great work! Thanks Adamm.I've pushed v8.0.8
Select Update Option:
[1] --> Check For And Install Any New Updates
[2] --> Check For Updates Only
[3] --> Force Update Even If No Updates Detected
[e] --> Exit
[1-3]: 2
[$] /jffs/scripts/firewall update check
[i] Skynet Update Detected - v8.0.8 (4f5770f4192bf4363f9df94fabc9e6e0)
[i] New Version Detected - Updating To v8.0.8 (4f5770f4192bf4363f9df94fabc9e6e0)
[i] Saving Changes
[i] Unloading Skynet Components
[i] No change to chart.js (MD5 matched)
[i] No change to chartjs-plugin-zoom.js (MD5 matched)
[i] No change to hammerjs.js (MD5 matched)
[i] No change to skynet.asp (MD5 matched)
[i] Updated firewall.sh
[i] Restarting Firewall Service
¦ Install Dir ¦ /tmp/mnt/RT-AX86UPro/skynet ¦
¦ FW Version ¦ ASUSWRT-Merlin v102.5_0 (Kernel 4.19.183) (Aug 3 2025) ¦
¦ iptables ¦ iptables v1.4.15 ¦
¦ ipset ¦ ipset v7.6, protocol version: 7 ¦
¦ Public IP ¦ xxx.xxx.xxx.xxx ¦
¦ WAN Info ¦ ppp0 - pppoe ¦
¦ Banned Countries ¦ ad ae af ag ai al am ao aq ar as aw ax az ba bb bd bf bg bh bi bj bl bm bn bo bq br bs bt bv bw bz cc cd cf cg ci ck cl cm cn co cr cu cv cw cx cy cz dj dm do dz ec¦
¦ Custom Filter URL ¦ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ¦
I upgraded to 8.0.8 and rebooted router, same result. restart skynet and problem fixed.Something is wrong with your inbound logging rule, please post the output of;
admin@RT-AX86U_PRO:/tmp/home/root# sh /jffs/scripts/firewall debug info
# Router Firewall And Security Enhancements #
# By Adamm - https://github.com/Adamm00/IPSet_ASUS#
# 04/01/2026 - v8.0.8 #
╔═════════════════════ System ═════════════════════════════════════════════════╗
║ Router Model │ RT-AX86U_PRO ║
║ Skynet Version │ v8.0.8 (04/01/2026) ║
║ └── Hash │ 4f5770f4192bf4363f9df94fabc9e6e0 ║
║ FW Version │ ASUSWRT-Merlin v102.6_0 (Kernel 4.19.183) (Nov 25 2025║
║ iptables │ iptables v1.4.15 ║
║ ipset │ ipset v7.6, protocol version: 7 ║
║ Public IP │ ║
║ WAN Info │ wan0 - dhcp ║
╔═════════════════════ Storage ════════════════════════════════════════════════╗
║ Install Dir │ /tmp/mnt/Asus/skynet ║
║ └── Used/Total │ 2.1G / 7.3G ║
║ SWAP File │ /tmp/mnt/Asus/myswap.swp ║
║ └── Size │ 2.0G ║
╔═════════════════════ Runtime ════════════════════════════════════════════════╗
║ Uptime │ 0 days, 0 hours, 19 minutes. ║
║ RAM Used/Total │ (425M / 994M) ║
╔═════════════════════ Logging ════════════════════════════════════════════════╗
║ Syslog Locations │ /jffs/syslog.log /jffs/syslog.log-1 ║
║ Skynet Log │ /tmp/mnt/Asus/skynet/skynet.log ║
║ └── Used/Total │ 900.0K / 10MB ║
║ Block Events │ 2734 (815 Unique IPs) ║
║ Monitor Span │ Jan 4 02:00:04 → Jan 4 06:59:40 ║
║ Device Name ║ Local IP ║ MAC Address ║
║ Test Description ║ Result ║
║ Internet-Connectivity ║ [Passed] ║
║ Public IP Address ║ [Passed] ║
║ Write Permission ║ [Passed] ║
║ Config File ║ [Passed] ║
║ Firewall-Start Entry ║ [Passed] ║
║ Services-Stop Entry ║ [Passed] ║
║ Service-Event Entry ║ [Passed] ║
║ Profile.add Entry ║ [Passed] ║
║ SWAP File ║ [Passed] ║
║ Cron Jobs ║ [Passed] ║
║ NTP Sync ║ [Passed] ║
║ Log Level 5 Settings ║ [Passed] ║
║ Duplicate Rules In RAW ║ [Passed] ║
║ IPSets ║ [Passed] ║
║ IPTables Rules ║ [Failed] ║
║ Local WebUI Files ║ [Passed] ║
║ Mounted WebUI Files ║ [Passed] ║
║ MenuTree.js Entry ║ [Passed] ║
║ 17/18 Tests Sucessful ║
║ Setting ║ Status ║
║ Skynet Auto-Updates ║ [Enabled] ║
║ Malware List Auto-Updates ║ [Enabled] ║
║ Logging ║ [Enabled] ║
║ Filter Traffic ║ [Enabled] ║
║ Unban PrivateIP ║ [Enabled] ║
║ Log Invalid Packets ║ [Enabled] ║
║ Log Size ║ [10MB] ║
║ Import AiProtect Data ║ [Enabled] ║
║ Secure Mode ║ [Enabled] ║
║ Extended Stats ║ [Enabled] ║
║ Fast Switch List ║ [Disabled] ║
║ Syslog Location ║ [Default] ║
║ IOT Blocking ║ [Disabled] ║
║ IOT Logging ║ [Enabled] ║
║ Country Lookup For Stats ║ [Enabled] ║
║ CDN Whitelisting ║ [Enabled] ║
║ Display WebUI ║ [Enabled] ║
[*] Rule Integrity Violation - [ #21 ]
[#] 30422 IPs (+0) -- 3608 Ranges Banned (+0) || Inbound -- Outbound Connecti]
After your next reboot, please capture the output of:I upgraded to 8.0.8 and rebooted router, same result. restart skynet and problem fixed.
iptables-save -t raw
nvram get wan0_ifname
Odd that in the log you posted the wan iface was listed as wan0.Code:iptables-save -t raw nvram get wan0_ifname
admin@RT-AX86U_PRO:/tmp/home/root# iptables-save -t raw
# Generated by iptables-save v1.4.15 on Sun Jan 4 09:51:44 2026
*raw
PREROUTING ACCEPT [2594:670511]
:OUTPUT ACCEPT [5880:6237578]
-A PREROUTING -i br+ -m set ! --match-set Skynet-MasterWL dst -m set --match-ses
-A PREROUTING -i br+ -m set ! --match-set Skynet-MasterWL dst -m set --match-seP
-A PREROUTING -i wan0 -m set ! --match-set Skynet-MasterWL src -m set --match-ss
-A PREROUTING -i wan0 -m set ! --match-set Skynet-MasterWL src -m set --match-sP
-A OUTPUT -m set ! --match-set Skynet-MasterWL dst -m set --match-set Skynet-Mas
-A OUTPUT -m set ! --match-set Skynet-MasterWL dst -m set --match-set Skynet-MaP
COMMIT
# Completed on Sun Jan 4 09:51:44 2026
admin@RT-AX86U_PRO:/tmp/home/root# nvram get wan0_ifname
wan0
The output lines are truncated by the terminal program.iptables-save -t raw
not sure what your asking, but I have Quantum Fiber using vlan201The output lines are truncated by the terminal program.
What is your wan setup? I thought I saw the original reply with eth0, then it showed as wan0. Maybe I imagined it.
# Generated by iptables-save v1.4.15 on Sun Jan 4 10:31:14 2026
*raw
PREROUTING ACCEPT [88872:26037810]
:OUTPUT ACCEPT [75011:44122182]
-A PREROUTING -i br+ -m set ! --match-set Skynet-MasterWL dst -m set --match-set Skynet-Master dst -j LOG --log-prefix "[BLOCKED - OUTBOUND] " --log-tcp-sequence --log-tcp-options --log-ip-options
-A PREROUTING -i br+ -m set ! --match-set Skynet-MasterWL dst -m set --match-set Skynet-Master dst -j DROP
-A PREROUTING -i wan0 -m set ! --match-set Skynet-MasterWL src -m set --match-set Skynet-Master src -j LOG --log-prefix "[BLOCKED - INBOUND] " --log-tcp-sequence --log-tcp-options --log-ip-options
-A PREROUTING -i wan0 -m set ! --match-set Skynet-MasterWL src -m set --match-set Skynet-Master src -j DROP
-A OUTPUT -m set ! --match-set Skynet-MasterWL dst -m set --match-set Skynet-Master dst -j LOG --log-prefix "[BLOCKED - OUTBOUND] " --log-tcp-sequence --log-tcp-options --log-ip-options
-A OUTPUT -m set ! --match-set Skynet-MasterWL dst -m set --match-set Skynet-Master dst -j DROP
COMMIT
# Completed on Sun Jan 4 10:31:14 2026
We use essential cookies to make this site work, and optional cookies to enhance your experience.
