SNMP monitoring issue after upgrading to 384.4_2 on RT-AC5300
orion44
I've always used SNMP to monitor my WAN traffic (among others) and after upgrading to 384.4_2 the data returned no longer includes WAN traffic and instead is the LAN traffic.
Prior setup under 380.xx
Monitoring interface 005 (eth0) via SNMP
Shows only WAN traffic
Current setup under 384
Shows all LAN traffic combined
I'm assuming the interface number wouldn't have changed as the result of a firmware update. Is there any hope to regain collecting WAN only traffic again?
orion44
To note, I've tried downgrading back to 380 and the monitoring of eth0 is still LAN traffic (combined). I re-upgraded to 384, did a factory default restore, new manual config, and still no dice. Is this something that transcends firmware? It seems odd it can't be remedied with the old FW version or a factory default restore. Losing out on WAN traffic data is pretty crappy as well.
orion44
Tools - System Information leads me to believe WAN traffic is now under vlan2 -- however the link state is down and no traffic is logged. Is this the root cause of the issue?
orion44
I'm not able to reproduce the issue with my RT-N66U since I can't run the new firmware. Is anyone else using the SNMP feature for monitoring and noticing a change in eth0 after updating to 384.x?
The only thing I haven't tried is going back to 380.x and then doing a factory reset. When I previously downgraded, it was a dirty downgrade. I'd rather not go backwards, but it might be my only option.
orion44
Success!
Steps to correct the SNMP issue:
  1. Flash 380.x firmware
  2. Perform factory reset
  3. Power cycle router (optional)
  4. Manually configure settings
  5. Confirm SNMP working as expected
  6. Restore prior config (optional)
I also noticed the average CPU usage dropped as well after reverting to 380.x
The increase was observed when I upgraded to 384.x last month
orion44
Any idea if the SNMP issue can be corrected in a future 384 release? I'd rather not stay on 380 long term.
RMerlin
Asuswrt-Merlin dev
If the Ethernet driver doesn't play nice with SNMP then there's nothing I can do about it.
Try monitoring the vlan instead, see if you get better results.
Sent from my P027 using Tapatalk
orion44
I already tried monitoring every port, vlan or otherwise. None of the them provided WAN traffic data. Guess I'll stay on 380 until the next botnet targeting ASUS devices bricks it. By then the hardware should need replacing anyway.
develox
Just as an added option, I use collectd to collect various data from the router, including WAN and LAN traffic.
orion44
Interesting, thanks for sharing. I've never used collectd previously and it looks way more accurate than SNMP under the current firmware.
cburkins
Bit of an older thread, but wondering if it's still impossible to use SNMP to track WAN-only traffic ?
