SOLVED: How to turn off LED in XD4 / ZenWifi Mini *nodes*?
peter500
Hi. I'm new to the SNB forums & new owner of an XD4 three unit setup, I have a question:
Can the LED on the ZenWifi Mini node units (model XD4N) be turned off? The admin web UI offers to configure the hardware WPS button as an LED toggle, but that setting only affects the main (Router/model XD4R) unit, not the XD4 "Node" satellites.
I'd be content to do this via SSH & command line, especially if I can reserve/hard-code the IP addresses of the nodes. ;-)
Thanks!
SOLVED: this can be done in the "Asus Router" app.
Click the Devices icon, then on the AiMesh tab you can select each XD4 unit seperately and turn its LED off.
