Sony Ericsson MD400 USB modem
DaniB
Hello, it would be possible to operate the MD400 with asus rt-N66?
i've tried the following commands:
usb_modeswitch -W -v 0x0fce -p 0xd0e1 -O 1
* usb_modeswitch: handle USB devices with multiple modes
* Version 1.2.3 (C) Josua Dietze 2012
* Based on libusb0 (0.1.12 and above)
! PLEASE REPORT NEW CONFIGURATIONS !
DefaultVendor= 0x0fce
DefaultProduct= 0xd0e1
TargetVendor= not set
TargetProduct= not set
TargetClass= not set
TargetProductList=""
DetachStorageOnly=0
HuaweiMode=0
SierraMode=0
SonyMode=1
QisdaMode=0
GCTMode=0
KobilMode=0
SequansMode=0
MobileActionMode=0
CiscoMode=0
MessageEndpoint= not set
MessageContent=""
NeedResponse=0
ResponseEndpoint= not set
InquireDevice enabled (default)
Success check disabled
System integration mode disabled
Looking for default devices ...
searching devices, found USB ID 0fce:d0e1
found matching vendor ID
found matching product ID
adding device
searching devices, found USB ID 058f:6366
searching devices, found USB ID 058f:6254
searching devices, found USB ID 1d6b:0002
searching devices, found USB ID 1d6b:0001
Found device in default mode, class or configuration (1)
Accessing device 004 on bus 001 ...
Getting the current device configuration ...
OK, got current device configuration (1)
Using first interface: 0x00
Using endpoints 0x01 (out) and 0x81 (in)
Inquiring device details; driver will be detached ...
Looking for active driver ...
No driver found. Either detached before or never attached
SCSI inquiry data (for identification)
Vendor String: SEMC
Model String: MMC Flash Card
Revision String: 0
USB description data (for identification)
Manufacturer: Sony Ericsson
Product: MMC Flash Card
Serial No.: 3578650240207990
Trying to send Sony control message
OK, control message sent, waiting for device to return ...
###### searching devices, found USB ID 058f:6366
# searching devices, found USB ID 0fce:d0e1
adding device
After 21 seconds: device came back, proceeding
Sending Sony control message again ...
-> device should be stable now. Bye.
System log extract after the first command:
usb 1-1.2: USB disconnect, address 4
usb 1-1.2: new high speed USB device using ehci_hcd and address 5
usb 1-1.2: configuration #2 chosen from 1 choice
usb-storage: device ignored
usb 1-1.2: unsupported MDLM descriptors
cdc_acm 1-1.2:2.1: ttyACM0: USB ACM device
cdc_acm 1-1.2:2.3: ttyACM1: USB ACM device
usbcore: registered new interface driver cdc_acm
drivers/usb/class/cdc-acm.c: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Second command:
modprobe usbserial vendor=0x0fce product=0xd0e1 -v -s
Third command:
comgt -d /dev/ttyUSB0
and the following output
admin@(none):/tmp/home/root# comgt -d /dev/ttyUSB0
***SIM ERROR***
Check device port configuration.
Check SIM is inserted
Test SIM in a mobile phone?
I currently use the MD400 under Windows without problems.
Any idea is welcomed.
THX
