My current situation:
Modem
Speedtouch 516 (bridge mode)
web interface: 192.168.1.254 and 10.0.0.138
Official firmware (latest)
Router
Asus RT N66U (PPPoE)
web interface: 192.168.2.1
DHCP: 192.168.2.2 <--> 192.168.2.254
Official firmware (3.0.0.4.374_720)
I need to share the external HD so that from outside LAN I can access it.
I have already activated AiDisk and FTP.
Everything works with flawlessly as long as router has public IP
Now I have noticed I cannot access modem web interface anymore because destination is unreachable
I have tried moving router to 192.168.1.2 (so that both router and modem are in the same subnet) but still the destination is unreachable
Now my questions:
1) Is this due to the the fact that LAN and WAN ports are separated so, even in the same subnet, I am not able to reach a WAN ip from LAN ip ?
2) Searching on internet I found there are two possible tricks to see modem web interface are:
a) Loopback
This way modem is connected to LAN port and I should be able to access it, but I am not sure about these:
a1) is there a security problem if I let modem connect to all LAN ports ? Aren't all router's security measures (NAT/Firewall/etc.) bypassed ?
a2) using this configuration can I keep modem in bridge mode ? I need router to keep public ip otherwise, with modem in routed PPPoE, router will have internal IP and I won't be able to access disks from outside
b) modify routing tables so that WAN IP can be reached from LAN IP
b1) Is it possible to achieve this with official firmware ?
b2) are there any security risks in doing that ?
3) Previously I was running this configuration:
Modem (Router PPPoE)
Router (DHCP)
I was able to access modem web interface but, since my router had internal ip, I could not see it from outside and, by consequence, also external hd was not accessible.
Are there any settings I can change so that I can access disk from outside using "double NAT configuration" ?
Modem
Router
<---LAN---> PC
ST516 <---WAN---> RT N66U ---<
<---USB---> External HD
Now my questions:
a) Loopback
_________________ | ___________ |
--------- ---<LAN ports> <WAN port>--- -------------
| Modem | | Router | | PC |
Router (DHCP)
