Suddenly, a router network share after update
HorstG
Hello after updating to the Merlin 39 I find then the LAN initiates a release RT-N66U , but fortunately without files.
I do not have a hard drive connected or FTP or Aicloud or or turned on.
Is this normal? Or do I need to adjust something?
THX Horst
-Login to the admin page and go to 'usb application'.
-Under 'Network Place(Samba) Share / Cloud Disk' click 'disable share'.
-Unless you're using it you may also want to go to 'Media server' tab here too, and disable the DLNA and iTunes server.
These have always been on by default in the 'out-of-the-box' config, so maybe something in the underlying codebase upgrade has reset it.
Hi under USB application find i
1. AIDISk
2. SERVERS CENTER
3. NetwerkPrint Server
4. 3G/4G
5. Download MAster
EDIT : Under Servers Center i find this!! Sorry
