Thermaltake
I have Asus rt-ac88u with merlin firmware on it. I would like to intensify signl a bit if thats possible. Would it make signal a little better if I put two tp-link 8dbi antennas ?
What issues are you having with the cameras? Frame rate lowering, frozen video, no signal? Are you using NVR software or any other means that can display frame rate? I maintain a few systems that have some wifi cams and have been down those roads.
I put AP in that apartmant because antennas in Dahua NVR have poor range, so AP Ubiquiti Loco M5 with wifi inside can boost signal to my router, and now sometimes when I open software for cameras they are offline and I have to wait for them to get online again few seconds. When signal is good they are always online without dropping. It varies around -41dB signal on that AP in that apartmant that is 3-4 walls away from my router, but I would like to boost it a bit more if it's possible with those antennas.
Your NVR is connected to the network via wifi? What kind of software are you opening to view cameras and how is that device connected?
Cameras are connected to nvr with wire. Ubiquiti Loco M5 (connected to NVR via POE) is just acting as amplifier for wifi signal(2.4Ghz) because my Asus can't reach nvr(bad internal antennas) from my place to that apartmant that is 3-4 walls away.
So my question is, if I mount those two tp-link 8dBi antennas on my Asus, would signal be better to Ubiquiti Loco M5, and without any inteference to the other devices connected to my Asus ?
And I am also worried if those two different antennas from two original ones will make some problems with 2.4 or 5Ghz network generally.
The antennae the router shipped with have been optimized in every regard to all the electronics prefacing them. While you may see a better signal to the Loco M5, it will almost certainly come at the cost of worst coverage for all other devices.
If you want to experiment, you may find something that works well enough and be almost worth it in the end. There is no guarantee though you'll find a solution where you just add range, without affecting everything else.
Instead of testing multiple antennae combinations, I would be considering the RT-AX88U instead to test with, including using another router as a wired AP that is physically closer to the Loco M5 you need to connect to.
Why do you suggest RT-AX88U, what are the difference between RT-AC88U and RT-AX88U, except processor, memory... they have as I see same dBi antennas, only few "commercial" unimportant stuff are on it, that I probably won't every use.
| Thread starter | Title | Forum | Replies | Date |
New Wi-Fi 7 dual-band AP with dual-antenna system | General Wi-Fi Discussion | 0 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
