Test for vpnclient running and restart it if it is
dlandon
I want to check for a vpnclient to be running and then restart it if it is. How do I check that a vpnclient is running? I don't want to start the vpnclient if it is not already running.
What router? What firmware? What VPN technology?
Sorry. I seem to have been too much into the moment and forgot to specify. I have a 5300 and I am using an OpenVPN client, firmware is 380.69 alpha 1.
The reason I feel I need to do this is that I use a nat-start script to make some iptables changes to forward ports from the VPN to the WAN. I need to do this because my VPN provider (NordVPN) blocks email ports. When I make changes on the GUI that run the nat-start script I seem to lose the port forwarding. I have to restart the VPN Client to get the port forwarding to work again. I want to restart the VPN Client at the end of the nat-start script if it is running and don't want to restart it if it is not running.
The nat-start code snippet should be useful?
Selective Routing with Asuswrt-Merlin
