TM-AC1900 (new) - can't log in [Solved]
SenorClean
I just bought a TM-AC1900 from Amazon (new - not refurb) to use as a network bridge (maybe play with Ai Mesh). I can't for the life of me log in to the admin console though!
Basically http://cellspot.router/ or http://192.168.29.1 prompt me to enter username/password - admin/admin or admin/password are rejected (admin/password is written on the sticker on the back).
I've tried wired, wireless, static IP, chrome/firefox/edge, using my phone... same result all-round.
I can get the mini-CFE to load fine, and have downgraded it with TM-AC1900_3.0.0.4_376_1703-g0ffdbba.trx but it still won't take my username/password.
30-30-30 reset doesn't change anything
It 'works' - in that if I plug something in to the WAN port it routes but obviously I can't configure anything (or cross-flash).
Any ideas?
EDIT: Solved with an NVRAM reset by booting while holding the WPS button. I'll leave the thread here in case it helps someone else some time.
