TM AC1900 turned Asus RT-AC68U help please.
JoBo
I flashed my TM 1900 to an RT-AC68U using information here and then updated to Merlins firmware.
I'm wondering if I choose the correct file based the version of my unit? Can anyone based on the small amount of info I have possibly tell me what version I have and is it the correct firmware?
Or possibly tell me where to find more?
thanks
JoBo
thanks
JoBo
Your firmware seems to be Merlin fork 374.43_2-20E9j9527
This is John's fork based on Merlin's firmware and according the following link should work with your router (as far as I know):
http://www.snbforums.com/threads/fork-asuswrt-merlin-374-43-lts-releases-v20e9-v22b6.18914/
Thanks for the quick reply:)
Seems to be working great except for some of the GUI screens don't display well or lock.
JoBo
JoBo
That's a symptom of not performing a factory reset after loading the firmware. Either do one via the Administration > System tab or by holding in the WPS button while powering on until the power LED starts a fast blink. After it reboots, you'll need to reconfigure.
PS - Also, it's highly recommended not to use any special characters (single or double quotes for example) in any of the name or password fields. These can cause gui problems in any of the ASUS firmware/forks.
Thanks John, I'll do that now.
**Updated** GUI viewing problem gone after restoring the defaults:D
Thanks again
JoBo
