Tor: How can an application access tor's Control Port (default 9051)?
brec
RT-AC86U, 386.3_2
On the VPN::Tor tab, the port fields are Trans (default 9040) and DNS (default 9053).
Tor enabled with those defaults is basically working based on a test using Firefox.
I have an application which accesses tor's Control Port (default 9051), and would like to know if I can use the router's tor instead of one running on my local host.
Edit: the application can't access the Control Port at 9051. I added "ControlPort 192.168.50.1:9051" to /tmp/torrc, but after I enabled/disabled Tor in the GUI the file was rewritten with the original contents.
Use a torrc custom config file. Open an ssh session and copy/paste the following into the window. It will automatically create the file. Then restart the tor process (or reboot).
cat << "EOF" > /jffs/configs/torrc.add
EOF
Make sure have "Enable JFFS custom scripts and configs" set to Yes under Administration->System.
P.S. I noticed the tor log (/tmp/torlog) refuses to open the port unless you also have some sort of authentication enabled.
Aug 31 10:45:51.313 [warn] You have a ControlPort set to accept unauthenticated connections from a non-local address.  This means that programs not running on your computer can reconfigure your Tor, without even having to guess a password.  That's so bad that I'm closing your ControlPort for you.  If you need to control your Tor remotely, try enabling authentication and using a tool like stunnel or ssh to encrypt remote access.
The only way it's going to work w/o authentication is if you use localhost (127.0.0.1) and the app that needs access to that port is also running on the router.
OK, thanks. The app is running on a Ubuntu system on the LAN. So I guess it's not going to work. Not a big deal, as tor can run on the Ubuntu system; I just thought it would be nifty to run it on the router.
