Trying to install a NUT client on RT-N66U
Martin Fishkov
My old RT-N66U (Firmware:380.70) has been a wifi access point, and a router connecting my NAS to the network.
Recently I installed a new UPC, and was looking for a way to get some stats.
The N66 has never had much to do, but now I thought to install the NUT client on it so I can see pretty pictures of my power usage.
Sadly I cannot even get AMTM installed on the thing. A 7.5 Gb usb drive is attached, formatted and scripts are enabled. The command
curl -Os https://diversion.ch/amtm/amtm && sh amtm
fails silently , or at least gives no visible result. Not even in the log.
The folder /jffs/scripts/ remains empty.
Am I expecting to much from the n66? Or am I missing something simple / silly..?..
Thnks!
Remove the "silent" flag from the curl command to see the error. I suspect it's a certificate issue.
curl -O https://diversion.ch/amtm/amtm
AMTM now installs, but trying to install entware then still fails- no reason given:
Getting from diversion.ch
! Module entware_setup.mod download failed
_____________________________________________
Trying to update gives me
! amtm: diversion.ch unreachable
Update(s) aborted, could not retrieve version
but why? Ping diversion.ch (from the network tools in the Merlin web ui) returns
PING diversion.ch (80.74.145.140): 56 data bytes
64 bytes from 80.74.145.140: seq=0 ttl=54 time=19.249 ms
64 bytes from 80.74.145.140: seq=1 ttl=54 time=20.051 ms
64 bytes from 80.74.145.140: seq=2 ttl=54 time=19.322 ms
64 bytes from 80.74.145.140: seq=3 ttl=54 time=20.368 ms
64 bytes from 80.74.145.140: seq=4 ttl=54 time=19.744 ms
--- diversion.ch ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 19.249/19.746/20.368 ms
I think it's the same certificate issue because your firmware is so old. Search the forums for previous discussions about this problem.
Yeah, the search feature seems a bit broken sometimes.
Try this:
echo insecure >> $HOME/.curlrc
curl -Os https://diversion.ch/scripts/ca_cert_check.sh && sh ca_cert_check.sh
