[TUTORIAL]Asterisk on the RT-N66U with Assuwrt & Entware
Jcconnell
The end goal (for me), is to use an Asterisk PBX with my Android phone for VOIP calling. I want to cut pbxes.org out of the mix. Since my router is running 24/7, it's the perfect place to put Asterisk.
So far I've managed to install Asterisk. I will add an additional section detailing how to make use of this with Android once I figure it out.
Note: You must have Merlin's Asuswrt and Entware installed on your RT-N66U. I would assume that this will also work on the RT-AC66U though I can't confirm. You will also need a text editor- I recommend nano.
Install the required packages:
opkg install asterisk18 asterisk-gui asterisk18-app-system asterisk18-chan-local
As listed in the Read Me, edit two configuration files. (README)
Change to the asterisk directory:
cd /opt/etc/asterisk/
List directory contents:
ls
Create http.conf:
nano http.conf
Copy and paste the following into the file:
[general]
enabled = yes
enablestatic = yes
Hit CTRL+X, then Y, then Enter to save.
Edit manager.conf:
nano manager.conf
Make sure these lines in your manager.conf match those listed below. NOTE- Double check to remove the comments and change [mark] to [admin]:
[general]
enabled = yes
webenabled = yes
[admin]
secret = putyourpasswordhere
read = system,call,log,verbose,command,agent,config,read,write,originate
write = system,call,log,verbose,command,agent,config,read,write,originate
Access your router Asterisk GUI via your LAN:
http://192.168.1.1:8088/static/config/index.html
admin/passwordyouusedinmanager.conf
NOTE: After logging in, the GUI would continuously reload, just barely flashing this long enough to be comprehensible: Asterisk is checking write permissions of GUI folder
-If you tried to access your Asterisk GUI before completing your configuration (as did I), you'll probably need to reload Asterisk so that the configuration file is reloaded. Specifically, the "originate" part of the "write:" line in the manager.conf file.
Connect to the Asterisk server:
asterisk -r
Reload Asterisk:
core restart now
This will dump you back out to the command prompt. Close the GUI webpage and reopen it, Log in and you should be good to go. If it doesn't work right away, give it a few minutes, it should clear the problem.
Anyone ever get any where with this? I got it all installed and running but am not sure about setting it up for Android devices.
I actually ended up pursuing another avenue and then later, losing interest altogether.
I did have it configured and working properly on the router so it's possible. This link demonstrates the steps required to set it up as well as the other avenue I ended up using: http://forum.xda-developers.com/nexus-4/general/guide-pbx-flash-piaf-amazon-ec2-free-gv-t2117336
Finally, I lost interest in the project after Google Hangouts in 4.4. Free calling is expected to be implemented in the first quarter of this year, so anytime now. In the meantime, my line has been switched to a company account and I get unlimited everything.
I try to run the command:
opkg install asterisk-gui
but I'm getting the following error:
Unknown package 'asterisk-gui'.
Collected errors:
 * opkg_install_cmd: Cannot install package asterisk-gui.
admin@RT-N66U:/tmp/home/root#
I have tried:
opkg update
but without luck.
I have RT-N66U with fw 376.44.
Thank you!
Collected errors:
I have tried:
opkg update
but without luck.
Thank you!
Use
opkg install asterisk18-gui
Jcconnell,
That Page cann't be find ( 404 Error )
Please check this and enter correct address for asterisk GUI
Use
Jcconnell,
I will try this in January and then I come back with feed back. Currently I don't have acces to the router.
Thank you!
Now, after after I input the login data I have the following error message: "Checking write permission for gui folder" and I can not acces the GUI.
Thank you!
