uiDivStats uiDivStats development version compatible with Diversion 5.0
314eter
You can test uiDivStats 3.1.0 if you already have it installed by running
Bash:
uiDivStats develop
Or if you don't have an older version installed
Bash:
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/uiDivStats/develop/uiDivStats.sh" -o "/jffs/scripts/uiDivStats" && chmod 0755 /jffs/scripts/uiDivStats && /jffs/scripts/uiDivStats install
WARNING: This is a development version, so it may cause issues or fail to upgrade.
Please report any issues you encounter here.
How long should it take for the database schema to upgrade? It's been sat like that for 5 minutes in amtm.
You can test uiDivStats 3.1.0 by running
Bash:
uiDivStats develop
Bash:
Welcome and thanks for your involvment of bringing uiDivStats up to speed.
That depends on the size of your database. But since it has to recreate the complete table, it can take a while. It took only a minute for me, but my database was only 50M.
Can you check the size of your database with du -h /opt/share/uiDivStats.d/dnsqueries.db when it's done, to get an idea of what to expect?
In yhat ca
Then I have a serious problem as the database is still upgrading but the file is only 12kB
EDIT: How do I uninstall this? I can't invoke the script in amtm as I get the database warning, even after a reboot.
I had uninstalled uiDivStats when I upgraded to Diversion 5.0. I installed uiDisStats 3.1.0 from scratch on four (4) different routers, and everything looks good so far — a lot of good info in a useful format. Thanks!
installed with no errors. appears to be working. thanks!
@Ripshod Did you have uiDivStats installed before? I think there's a bug in the script that will indefinitely try to upgrade the database if the database file is missing, but I'm not sure how that can happen. Which commands did you run to upgrade?
Thanks. I sorted it though.
I deleted the script and the folder in /shares/ then reinstalled. Running fine now. Can I suggest you remove the "uidivstats develop" advice as that suggests an upgrade from the previous version, or at least a warning? My fault, I should have removed the old version ages ago.
Running uiDivStats develop should work to upgrade from a previous version, assuming the database file is still there. The upgrade script doesn't check that right now (I'm fixing that), and can end up in an infinite loop.
My assumption is that you did have an older version of uiDivStats installed, but didn't have the old database file in /opt/share/uiDivStats.d/dnsqueries.db anymore. Can that be correct?
Sorry to jump in but ....
Getting same problem after running '/jffs/scripts/uiDivStats uninstall' then deleting all directories associated with uidivstats that are left, to enable 'Clean' install.
Install from scratch using your install command line works.
Appears to be working from the added tab in the GUI.
Select J5 from AMTM and the 'Upgrading database schema, this will take a while!' message appears and stays with no end !!!???
Help !!!! :)
Incorrect. The old dnsmasq.db file was still there from 30th December - when I installed Diversion 5 and uiDivStats was automatically disabled. I never uninstalled uiDivStats.
Help !!!! :)
To confirm, you deleted the /opt/shares/uiDivStats.d/ folder? And you rebooted before installing again?
Complete install from command line (not previously installed), all appears to be working fine. The return of an old friend!
Type 65 seems to now show as HTTPS, interesting…….
Yes, I did delete the folder and did reboot.
I did find the .newallowed file was needed and created it myself :)
[Was not sure where it came from !!!???]
Did 'Clean' install again from scratch and the .newallowed file allowed the J5 AMTM option to run OK.
DNS resource record type 65 is now known as HTTPS .... apparently !!!
It threw me at first !!!
[ See ---> rfc9460 PDF ]
That's the case since dnsmasq 2.87 and newer, which is included in asuswrt-merlin since 388.2. But the uiDivStats filters should still be updated.
Also upgraded from an existing install.
Database upgrade took a couple of minutes (but less than 5).
Fully working again.
Thank you very much!
